My Kitchen Aid lower oven will not heat up. Top oven works fine. The control touch panel and all fuctions / fans/ etc work properly, just no heat. Reading other posts in this forum I have done the following: 1. Checked safety thermostat, switched with top oven 2. Checked heating elements, switched with top oven 3. Checked door latches and switches 4. Checked conductivity of all heating element circuits 5. Checked control panel, checked connections (unplugged and replugged) 6. No 220v to lower oven elements
Top oven continues to work fine, even with lower oven components. Lower oven, no change, no heat.
Question: What else can I check or do, or is it time to replace the control assembly? Thanks for all help!!! :confused:
Bump Anyone have any ideas?
:confused: :confused: :confused:
Can anyone help me with this problem????? :( :( :(
