My Maytag oven control touch panel does not work, only the cancel button plus one other function works, I have tried turning the power off to re set it but still not working, unable to even set the clock, will it be the touch screen or the control card behind ?? I have found the circuit board s available but cannot find a front touch panel ?? Thanks Alan.
Originally Posted by: Alan Wilson My Maytag oven control touch panel does not work, only the cancel button plus one other function works, I have tried turning the power off to re set it but still not working, unable to even set the clock, will it be the touch screen or the control card behind ?? I have found the circuit board s available but cannot find a front touch panel ?? Thanks Alan. Hope you are able to advise !
Originally Posted by: Alan Wilson Hope you are able to advise ! When will I have a reply ??
