I bought this hood in 2006 and have used it lightly (less than 50 times). Recently, the light quit working. After a call to Kobe tech, they said its either the "processor" board or LCD. I replaced the former and that made the fan quit too. Kobe says its very likely to be the LCD. Coincidentally, they have no spares to sell, so I gather this has happened before. :-(
Before sending this $1500 unit to the junk pile, I thought I'd try to have the LCD repaired. The display is fine, but the fan, timer and light controls don't work the way they should. I doubt anyone can find a repair manual. Can anyone recommend a place to send the LCD for repair?
UPDATE:Problem solved. The LCD board & box contained a dead spider & web. Cleaned things up and everything works.
