We have a GE XL44 Gas range that is set up for propane. It came with the home in 2000.Has worked fine for years. About a month ago the oven quit being reliable.We cant even cook a pizza through.I just set the oven nob to 450. Within a couple seconds the electric glow plug lit up.Soon the burner ignighted.After 15 minutes the oven was at 325.At 20 minutes the burner was off and the oven was at 375.At 23 minutes the burner reignited.At 25 minutes the burner was out and the oven was at 400.At that point the burner would turn on and off maintaining a temp of about 405.Ive tried putting the dial at 500 to preheat then turn it down to 450. but then the burner doesnt reignite.ANYBODY GOT ANY IDEAS?
