oven comes up to correct temperture,but does not cook food in center, replace oven senor and control panel:confused:
Originally Posted by: mikedupre oven comes up to correct temperture,but does not cook food in center, replace oven senor and control panel:confused: How are you checking oven temp, based on control panel display or with a manual oven thermometer ? If you already replaced sensor and control panel, you might have to recalibrate the board. I think instructions for adjusting the temp display reading is usually in the manual.
