Getting the f5 e1 message when we try to self clean oven. Believe we may have a bad solenoid.
What is the range for resistance when testing. Should it vary if the solenoid is open or closed.
Can the voltage to the solenoid be measured with a voltmeter when activated. I have read that sometimes the voltage to operate may be in short cycles. If it can be read, what voltage should I be getting.
What is the best method to check the control board to make sure it is communicating with the solenoid. All other functions work but I want to make sure the control board is telling the solenoid to operate.
Thanks for your help
