oven will not maintain temp. if you bake a cake per the directions first it will be okay. then you put in some cookies without changing temp and that batch could take up to a hour to bake? any suggestions.
thanks, mac
Quote:oven will not maintain temp. any suggestions? That appears to be a gas oven utilizing a hot surface (glow ignitor) ignition system. A first step in diagnosing problems in such a system is observing what the oven ignitor(s) are doing when the oven is turned on and should be heating but isn't. You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link: LINK > Understanding Gas Oven Ignition SystemsJFYI Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
