Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Very srong smel of gas (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/40524-very-srong-smel-gas.html)
Amir 07-14-2009 01:45 AM
Wen I turen on the stove it takes long time for prehiting with smel of gas,after a wile wen it turned on the all kitchen was shaiking.The smel is ther even wen the oven is hot and warking.I have no problem with the range and wen the oven is not on ther is no smel.
Gene 07-14-2009 05:36 PM
Most likely the problem is a bad oven Bake igniter (#17 on the diagram).
- The Bake igniter Part number: AP4041245
It comes without the mounting bracket. You have to use the old bracket. Be careful not to touch the igniter coil.
Here are the breakdown diagrams and Replacement parts for AMANA ARG7302WW | AppliancePartsPros.com
Amir 07-19-2009 03:53 PM
Thak you.
[quote=Gene;107114]Most likely the problem is a bad oven Bake igniter (#17 on the diagram).
Gene.[/quot
Thank you it works perfectly
Gene 07-20-2009 09:00 PM
You are welcome. I'm glad you were able to fix it.
