the button on the control display to adjust the heat for the oven does not work oven will heat but can't turn up the heat it used to beep when you press the button now you press nothing happens? i can turn the heat down but can't turn it back up...and the the timer button does not work it used to beep what can be the problem?
Sounds like a possible keypad problem. See if there are any more buttons that don't beep when you press them.
