Discuss
smell gas!
 in
when we try to pre-heat oven does not ignite and we smell gas. i replace the igniter for the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » smell gas!
  #1 (permalink)
Old 07-13-2009, 07:06 PM
grapal29 grapal29 is offline
Junior Member
grapal29 is on a distinguished road
Unhappy smell gas!
Model Number: ARGS7650ss   Brand: Amana   Age: 5 - 10 years
when we try to pre-heat oven does not ignite and we smell gas. i replace the igniter for the broiler about a year and that still works fine. cook top burners also operating well. any guidance as to what is wrong with the oven? i thought that there were controlls that would not allow the gas to flow if the igniter was not hot enough.. ??
Related Models
Amana ARGS7650SS Range - S/c S/i Gas
Amana ARGS7650WW Range - S/c S/i Gas
Amana ARH660 Range - S/c S/i Ddraft Gas
Amana ARH660HR Range - S/c S/i Ddraft Ele
Amana ARH664E Range - S/c S/i Ddraft Ele
Amana ARH664WW Range - S/c S/i Ddraft Ele
Amana ARH665E Range - S/c S/i Ddraft Ele
Amana ARH665WW Range - S/c S/i Ddraft Ele
Amana ARH667E Range - S/c F/s Ele
Amana ARH667WW Range - S/c S/i Ddraft Ele
Amana ARH6700E Range - S/c S/i Ddraft Gas
Amana ARH6700LL Range - S/c S/i Ddraft Gas
Amana ARH6700WW Range - S/c S/i Ddraft Gas
Amana ARH6710E Range - S/c S/i Ddraft Gas
Amana ARH6710LL Range - S/c S/i Ddraft Gas
Amana ARH6710WW Range - S/c S/i Ddraft Gas
Amana ARHC7700E Range - S/c S/i Ddraft Ele
Amana ARHC7700LL Range - S/c S/i Ddraft Ele
Amana ARHC7700WW Range - S/c S/i Ddraft Ele
Amana ARHC8700E Range - S/c F/s Ele
Amana ARHC8700LL Range - S/c F/s Ele
Amana ARHC8700WW Range - S/c F/s Ele
Amana ARHSC8750E Range - S/c S/i Ddraft Ele
Amana ARHSC8750WW Range - S/c S/i Ddraft Ele
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L Range - S/c S/i Ddraft Gas
Amana ARO3100W Range - S/c S/i Ddraft Gas
Amana ARO3400L Range - S/c S/i Ddraft Gas
Amana ARO3400W Range - S/c S/i Ddraft Gas
Amana ARR-201 Range - S/c S/i Ddraft Ele
Amana ARR-401 Range - S/c S/i Ddraft Gas
Amana ARR-402 Range - S/c S/i Ddraft Gas
Amana ARR-405 Range - S/c S/i Ddraft Gas
Amana ARR-412 Range - S/c S/i Ddraft Ele
Amana ARR-415 Range - S/c S/i Ddraft Ele
Amana ARR101W Range - S/c S/i Ddraft Ele
Amana ARR301 Range - S/c S/i Ddraft Ele
Amana ARR301W Range - S/c S/i Ddraft Ele
Amana ARR303 Range - S/c S/i Ddraft Ele
Amana ARR303W Range - S/c S/i Ddraft Ele
Amana ARR305 Range - S/c S/i Ddraft Ele
Amana ARR3100L Range - S/c S/i Ddraft Gas
Amana ARR3100NL Range - S/c S/i Ddraft Gas
Amana ARR3100NW Range - S/c S/i Ddraft Gas
Amana ARR3100W Range - S/c S/i Ddraft Gas
Amana ARR3400L Range - S/c S/i Ddraft Gas
Amana ARR3400W Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 07-14-2009, 05:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Very likely the problem is a bad Bake igniter. You can learn how oven igniter works from one of our previous posts: Oven won't lite?
- The igniter Part number: AP4041245
The new igniter comes without a mounting bracket. You have to use the old bracket. Be very careful not to brake and not to touch the igniter coil.
Here are the breakdown diagrams and Replacement parts for AMANA ARGS7650SS | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Smell joek74 Oven Repair (including Ranges and Cooktops) 1 06-06-2009 04:08 PM
Gas smell that is really bad geronimocka Oven Repair (including Ranges and Cooktops) 6 05-31-2009 12:16 AM
gas smell rich123 Dryer Repair 2 02-16-2009 12:56 PM
Bad LP Smell Arjay Oven Repair (including Ranges and Cooktops) 6 12-10-2008 12:57 PM
Gas Smell emptypckts Oven Repair (including Ranges and Cooktops) 0 04-14-2008 06:58 PM
