Questions: The inside oven window of our GE Dual Wave II (March 1990), KP68G0K3BC, serial number FD902636G is cracked. I would like to purchase a replacement window (or the GE package), but I am being told the replacement package is discontinued...Any ideas other than going to a glass store...
The information you received is correct. This part has been discontinued by the manufacturer. I do not think a glass store could help because this is not a regular glass.
If anyone has this problem in the future, the part is no longer available (I called multiple new and used appliance sources) so I had to remove the window pack and replace the high heat glass...Works like new!!!
Thank you for sharing the helpful information. We are gald to hear you found the way to fix it.
