Discuss
ignitor
 in
Ignitor continues to click when burner knob is turned off. Turning knob back and forth eventually turns ignitor off, but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ignitor
  #1 (permalink)
Old 07-13-2009, 01:44 PM
jstival1 jstival1 is offline
Junior Member
jstival1 is on a distinguished road
Default ignitor
Model Number: HGS255UC/02   Brand: Bosch   Age: 1 - 5 years
Ignitor continues to click when burner knob is turned off. Turning knob back and forth eventually turns ignitor off, but took longer as time went on. We have stopped using the burner until I find out if I can replace a part myself or if I need a repair by a professional. Thanks in advance for assistance.
Related Models
Thermador HGSI42TS
Thermador HGSW36TS
Maytag HJ61201JRT Electric Water Heater
Maytag HJ61202JRT Electric Water Heater
Maytag HJ6301JLS Electric Water Heater
Maytag HJ6301JLSCSA Electric Water Heater
Maytag HJ6301JRT2 Electric Water Heater
Maytag HJ6301JRT2CSA Electric Water Heater
Maytag HJ6302JLS Electric Water Heater
Maytag HJ6302JLSCSA Electric Water Heater
Maytag HJ6302JRT2 Electric Water Heater
Maytag HJ6302JRT2CSA Electric Water Heater
Maytag HJ6302JRT2O Electric Water Heater
Maytag HJ630NORT Gas Water Heater
Maytag HJ630NORT2 Gas Water Heater
Maytag HJ630NORT2CGA Gas Water Heater
Maytag HJ630NORTCGA Gas Water Heater
Maytag HJ630PORT Gas Water Heater
Maytag HJ630PORT2 Gas Water Heater
Maytag HJ630PORT2CGA Gas Water Heater
Maytag HJ630PORTCGA Gas Water Heater
Maytag HJ6401JLS Electric Water Heater
Maytag HJ6401JLSCSA Electric Water Heater
Maytag HJ6401JRS Electric Water Heater
Maytag HJ6401JRSCSA Electric Water Heater
Maytag HJ6401JRT2 Electric Water Heater
Maytag HJ6401JRT2CSA Electric Water Heater
Maytag HJ6401JRT2CSAF Electric Water Heater
Maytag HJ6401JRT2F Electric Water Heater
Maytag HJ6401JT4W Electric Water Heater
Maytag HJ6401JT4WCSA Gas Water Heater
Maytag HJ6402JLS Electric Water Heater
Maytag HJ6402JLSCSA Electric Water Heater
Maytag HJ6402JRS Electric Water Heater
Maytag HJ6402JRSCSA Electric Water Heater
Maytag HJ6402JRT2 Electric Water Heater
Maytag HJ6402JRT2CSA Electric Water Heater
Maytag HJ6402JRT2CSAF Electric Water Heater
Maytag HJ6402JRT2F Electric Water Heater
Maytag HJ6402JT4W Electric Water Heater
Maytag HJ6402JT4WCSA Gas Water Heater
Maytag HJ640NBDS Gas Water Heater
Maytag HJ640NBDSCGA Gas Water Heater
Maytag HJ640NBDVT Gas Water Heater
Maytag HJ640NBDVTCGA Gas Water Heater
Maytag HJ640NBPDT Gas Water Heater
Maytag HJ640NBPDTCGA Gas Water Heater
Maytag HJ640NBRS Gas Water Heater
Maytag HJ640NBRSCGA Gas Water Heater
Maytag HJ640NBRSW Gas Water Heater
Maytag HJ640NBRT Gas Water Heater
Maytag HJ640NBRT2 Gas Water Heater
Maytag HJ640NBRT2CGA Gas Water Heater
Maytag HJ640NBRTCGA Gas Water Heater
Maytag HJ640NBRTF Gas Water Heater
Maytag HJ640NBRTFCGA Gas Water Heater
Maytag HJ640NOCT42W Gas Water Heater
Maytag HJ640NOCT52W Gas Water Heater
Maytag HJ640NOLS Gas Water Heater
Maytag HJ640NOLSCGA Gas Water Heater
Maytag HJ640NORS Gas Water Heater
Maytag HJ640NORS2 Gas Water Heater
Maytag HJ640NORS2CGA Gas Water Heater
Maytag HJ640NORSCGA Gas Water Heater
Maytag HJ640NORT Gas Water Heater
Maytag HJ640NORT2 Gas Water Heater
Maytag HJ640NORT2CGA Gas Water Heater
Maytag HJ640NORTCGA Gas Water Heater
Maytag HJ640NOVET Gas Water Heater
Maytag HJ640NOVET2 Gas Water Heater
Maytag HJ640NOVET2CGA Gas Water Heater
Maytag HJ640NOVETCGA Gas Water Heater
Maytag HJ640NOVIT Gas Water Heater
Maytag HJ640NOVIT2 Gas Water Heater
Maytag HJ640PBDS Gas Water Heater
Maytag HJ640PBDSCGA Gas Water Heater
Maytag HJ640PBDVT Gas Water Heater
Maytag HJ640PBDVTCGA Gas Water Heater
Maytag HJ640PBPDT Gas Water Heater
Maytag HJ640PBPDTCGA Gas Water Heater
Maytag HJ640PBRS Gas Water Heater
Maytag HJ640PBRSCGA Gas Water Heater
Maytag HJ640PBRT Gas Water Heater
Maytag HJ640PBRT2 Gas Water Heater
Maytag HJ640PBRT2CGA Gas Water Heater
Maytag HJ640PBRTCGA Gas Water Heater
Maytag HJ640PBRTF Gas Water Heater
Maytag HJ640PBRTFCGA Gas Water Heater
Maytag HJ640POCT42W Gas Water Heater
Maytag HJ640POCT52W Gas Water Heater
Maytag HJ640POLS Gas Water Heater
Maytag HJ640POLSCGA Gas Water Heater
Maytag HJ640PORS Gas Water Heater
Maytag HJ640PORS2 Gas Water Heater
Maytag HJ640PORS2CGA Gas Water Heater
Maytag HJ640PORSCGA Gas Water Heater
Maytag HJ640PORT Gas Water Heater
Maytag HJ640PORT2 Gas Water Heater
Maytag HJ640PORT2CGA Gas Water Heater
Maytag HJ640PORTCGA Gas Water Heater
Maytag HJ640POVET Gas Water Heater
Maytag HJ640POVET2 Gas Water Heater
Maytag HJ640POVET2CGA Gas Water Heater
Maytag HJ640POVETCGA Gas Water Heater
Maytag HJ640POVIT Gas Water Heater
Maytag HJ640POVIT2 Gas Water Heater
Maytag HJ6501JLSW Electric Water Heater
Maytag HJ6501JLSWCSA Electric Water Heater
Maytag HJ6502JLSW Electric Water Heater
Maytag HJ6502JLSWCSA Electric Water Heater
Maytag HJ650NBDS Gas Water Heater
Maytag HJ650NBDSCGA Gas Water Heater
Maytag HJ650NBDVT Gas Water Heater
Maytag HJ650NBDVTCGA Gas Water Heater
Maytag HJ650NBPDT Gas Water Heater
Maytag HJ650NBPDTCGA Gas Water Heater
Maytag HJ650NBRT Gas Water Heater
Maytag HJ650NBRT2 Gas Water Heater
Maytag HJ650NBRT2CGA Gas Water Heater
Maytag HJ650NBRTCGA Gas Water Heater
  #2 (permalink)
Old 07-13-2009, 03:13 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Ignition switch?
There should be an electrical switch near the burner valve. It is what powers the spark module when turned on. That switch may be defective or its mounting loose, etc.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
looking for ignitor p/n willhess Oven Repair (including Ranges and Cooktops) 9 06-24-2009 05:29 AM
ignitor Bobkc Dryer Repair 0 03-14-2009 01:05 PM
Gas ignitor Loretta Oven Repair (including Ranges and Cooktops) 3 03-30-2008 06:39 PM
R & R Ignitor lenboy1971@yahoo.com Heating, Ventilation, and Air Conditioning (HVAC) 1 01-02-2008 12:04 AM
how to get to the ignitor christena Dryer Repair 1 11-12-2007 08:45 PM
