JennAir Duel Fuel range model SVD48600P Symptom: Oven does not heat at all (no bake - no broil). Everything else works fine.
Oven sensor ohm'd at about 1100 - OK Bake and broil elements both ohm'd at about 20 - OK High limit has continuity
I believe the issue is with the oven relay board which happens to be part of the touch pad control panel. Unfortunately the part (JennAir # 5700M662-60) is discontinued and not in stock anywhere. So I hope to fix it. Really hope to avoid junking an otherwise good oven.
When I turn on bake or broil the relays (depending on which I turned on) make a click-pause-click sound about every 30 seconds or so. Sounds like the relay closing then opening again immediately (about 1 second later). High limit and over sensor are both good. Since the relays appear to be closing immediately I'm wondering if the portion of the board that interprets the over sensor resistance could be at fault and incorrectly signalling the relays to close?
All advice appreciated.
There is a company who does repair such parts. Use the old part number 71002959 for this control board when you'll speak with them. Gene.
