Discuss
spark igniter on two gas control valves doesn't work
 in
This model has the spark igniter built into the gas control I believe. When turning on a burner, the igniter
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » spark igniter on two gas control valves doesn't work
  #1 (permalink)
Old 01-16-2012, 08:32 AM
Junior Member
oi2ks is on a distinguished road
Default spark igniter on two gas control valves doesn't work
Model Number: S 64h-4tkxw   Brand: Magic Chef   Age: More than 10 years
This model has the spark igniter built into the gas control I believe. When turning on a burner, the igniter sparks all four burners. Two of the burners will work but need to be lit by turning on the igniter from a different valve. It's otherwise in good shape and I would prefer not to replace it. Can parts be obtained to repair this problem?
Ads By Google
Related Models
Amana S-22 REF - SXS/I&W
Amana S100 MISC / ACCESSORY
Jenn-Air S100 RANGE- S/I STD DDRAFT ELE
Hoover S1003
Hoover S1005--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Jenn-Air S101 RANGE- S/I STD DDRAFT ELE
Hoover S1015--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015030 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015031 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015032 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015033 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015075 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1017
Hoover S1019--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1019030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1021--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1021030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1029--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1029075 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1049--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1049-22
Hoover S1049060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Jenn-Air S105 RANGE- S/I STD DDRAFT ELE
Jenn-Air S105-C RANGE- S/I STD DDRAFT ELE
Admiral S1050EH-Z RANGE- F/S STD ELE
Admiral S1050EJ-Z RANGE- F/S STD ELE
Hoover S1055
Hoover S1057300
Hoover S1057400
Hoover S1057600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1057700
Hoover S1057800
Hoover S1059--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059130 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1061
Hoover S1063
Admiral S1068H-CZW RANGE- S/C S/I ELE
Admiral S1068J-CHZW RANGE- S/C D/I ELE
General Electric S1070A0WW Washer
General Electric S1070A1WW Washer
General Electric S1070A2WW Washer
General Electric S1070A4WW Washer
General Electric S1070A5WW Washer
Admiral S1070EH-KZ RANGE- F/S STD GAS
Admiral S1070EH-Z RANGE- F/S STD GAS
Admiral S1070EJ-KZ RANGE- F/S STD GAS
Admiral S1070EJ-Z RANGE- F/S STD GAS
Hoover S1071--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1071800 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1073--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1075--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1075033
Hoover S1075060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1077--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1077060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Admiral S1078EH-KZ RANGE- F/S STD GAS
Admiral S1078H-KLVW RANGE-F/S CONT CLEAN GAS
Admiral S1078W-KLVW RANGE-F/S CONT CLEAN GAS
Hoover S1079--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1079060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1083--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1083100 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1088H-CKZW RANGE- S/C S/I GAS
Admiral S1088J-TKZW RANGE- S/C S/I GAS
Hoover S1093
Hoover S1095
Jenn-Air S110 RANGE- S/I STD DDRAFT ELE
Hoover S1101---
Hoover S1103--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1105--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1112--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1112050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1114--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1117900 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1117981 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1120--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1120050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1127--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1133--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1135--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1137--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1137980 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1141--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1147--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1147050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1147900 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1151L-30 SURFACE UNIT- ELE
Admiral S1151L-36G SURFACE UNIT- ELE
Hoover S1156--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1171L-30 SURFACE UNIT- GAS
Admiral S1171L-30K SURFACE UNIT- GAS
Admiral S1171L-36GK SURFACE UNIT- GAS
Admiral S1172L-30K SURFACE UNIT- GAS
Jenn-Air S120 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S120-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S121 RANGE- S/C S/I DDRAFT ELE
Hoover S1211--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1215--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1221--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1223--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Jenn-Air S125 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S125-C RANGE- S/C S/I DDRAFT ELE
Hoover S1311--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1311020 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1315--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1319--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1323--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1329--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1331--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1335--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1337--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1339--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1347--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1349--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1353--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Jenn-Air S136 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S136-C RANGE- S/C S/I DDRAFT ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark on Igniter for top burner Spark is WEAK or sometimes NO spark!! mobfather Oven Repair (including Ranges and Cooktops) 0 02-11-2011 10:10 AM
Spark Igniter KMcDonald Oven Repair (including Ranges and Cooktops) 0 01-24-2011 09:08 AM
GE Spark Igniter skassamali Oven Repair (including Ranges and Cooktops) 0 11-15-2009 10:57 AM
Replacing Spark Igniter/Spark Electrode wolnerd Oven Repair (including Ranges and Cooktops) 1 01-17-2009 10:58 AM
Spark Igniter pgronvall Oven Repair (including Ranges and Cooktops) 0 11-08-2007 05:55 AM
