DeALLEN03
#1 Posted : Sunday, July 12, 2009 7:41:29 PM(UTC)
DeALLEN03
Got a replacement part from website & in taking old part out marked wires as to which locations they were plugged into so that I could connect new pigtailed part back the same way. The oven control panel does now "light" red light when oven temp control is turned on (didn't light before part replacement) but the ignitor doesn't appear to get hot/glow to light oven. The broiler ignitor works fine. Could there be another part that went out with the failing ignitor or do I have something not making connection? I used wire splice connectors & not wirenuts provided as they are below oven floor away from heat under the back/drawer area. Could that be a problem? Please advise & "THANK YOU" in advance. Later, Douglas Allen
#2 Posted : Monday, July 13, 2009 4:16:19 PM(UTC)
Hi Douglas,
The first thing I would do is double check the wires connection for a good tight contact.
What is the complete model number of the oven?
DeALLEN03
#3 Posted : Monday, July 13, 2009 7:05:36 PM(UTC)
DeALLEN03
Hey Gene thanks for the reply. I'll check connections in the AM but in meantime here the complete story on oven/range; GE BrandXL44 Self-Cleaning range, model# RGB745BEA4AD; Serial# VZ203629R was in home when purchased 7yrs ago & was about 1-1.5 yrs older from when purchased. Later, Douglas:D
Replaced Ignitor, Still Not Glowing (Oven Repair (including Ranges and Cooktops))
by ryanclose 8/28/2012 5:16:51 PM(UTC)
Oven clicks, won't light (replaced ignitor already) (Oven Repair (including Ranges and Cooktops))
by kbeiii 9/8/2011 4:32:47 PM(UTC)
Gas Dryer - Replaced Ignitor, Still no heat (Dryer Repair)
by mbeszka 11/17/2010 4:51:23 AM(UTC)
Oven and broiler do not light, stove works, already replaced ignitor. Grrrr! (Oven Repair (including Ranges and Cooktops))
by ncduckman 2/23/2009 5:05:50 PM(UTC)
Whirlpool oven won't work - replaced ignitor (Oven Repair (including Ranges and Cooktops))
by tradermon23 8/27/2008 3:11:31 AM(UTC)
Replaced ignitor worked once then nothing (Oven Repair (including Ranges and Cooktops))
by cjkms 8/22/2008 6:31:44 AM(UTC)
