Discuss
Resurfacing inside of oven
 in
Is there a product for a do-it-yourselfer to resurface/recoat the inside of an oven? Over the years the oven racks
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Resurfacing inside of oven
  #1 (permalink)
Old 01-12-2012, 12:07 PM
Junior Member
JGAmo is on a distinguished road
Default Resurfacing inside of oven
Model Number: FGF379WJCA   Brand: Frigidaire   Age: More than 10 years
Is there a product for a do-it-yourselfer to resurface/recoat the inside of an oven? Over the years the oven racks have worn away the coating and the remaining surface has begun to show rust. The oven racks no longer slide smoothly and they also appear to have warped.
Related Models
Frigidaire FGF379WJCA GAS, RANGE
Frigidaire FGF379WJCB GAS, RANGE
Frigidaire FGF379WXACA Frigidaire/gas Range
Frigidaire FGF379WXBCA Frigidaire/gas Range
Frigidaire FGF380MXDCA Frigidaire/gas Range
Frigidaire FGF380MXFBA Frigidaire/gas Range
Frigidaire FGF380MXFBB GAS RANGE
Frigidaire FGF380MXFCA Frigidaire/gas Range
Frigidaire FGF380MXFSA Frigidaire/gas Range
Frigidaire FGF380MXFSB GAS RANGE
Frigidaire FGF382HBA GAS RANGE
Frigidaire FGF382HBB GAS RANGE
Frigidaire FGF382HBD GAS RANGE
Frigidaire FGF382HCA GAS RANGE
Frigidaire FGF382HCC GAS RANGE
Frigidaire FGF382HCD GAS RANGE
Frigidaire FGF382HCE GAS RANGE
Frigidaire FGF382HCF GAS RANGE
Frigidaire FGF382HCG GAS RANGE
Frigidaire FGF382HCH GAS RANGE
Frigidaire FGF382HCJ GAS RANGE
Frigidaire FGF382HSA GAS RANGE
Frigidaire FGF382HSB GAS RANGE
Frigidaire FGF382HSC GAS RANGE
Frigidaire FGF382HSD GAS RANGE
Frigidaire FGF382HSE GAS RANGE
Frigidaire FGFB337GCA Frigidaire/range
Frigidaire FGFB337GCB GAS RANGE
Frigidaire FGFB337GCC GAS RANGE
Frigidaire FGFB337GCD GAS RANGE
Frigidaire FGFB337GCE GAS RANGE
Frigidaire FGFB337GCF GAS RANGE
Frigidaire FGFB337GCG GAS RANGE
Frigidaire FGFB33WHSA Frigidaire/gas Range
Frigidaire FGFB33WHSB RANGE
Frigidaire FGFB33WHSC RANGE
Frigidaire FGFB55ASA Frigidaire/range
Frigidaire FGFB55ASB Frigidaire/range
Frigidaire FGFB55ASC Frigidaire/gas Range
Frigidaire FGFB55ASD Frigidaire/gas Range
Frigidaire FGFB64CJSA RANGE
Frigidaire FGFB64CJSB RANGE
Frigidaire FGFB64CJSC RANGE
Frigidaire FGFB64CJSD RANGE
Frigidaire FGFB66ASA Frigidaire/range
Frigidaire FGFB66ASB Frigidaire/range
Frigidaire FGFB66ASC Frigidaire/gas Range
Frigidaire FGFB66ASD Frigidaire/gas Range
Frigidaire FGFB66ECB Frigidaire/gas Range
Frigidaire FGFB66ECC Frigidaire/gas Range
Frigidaire FGFB66ECD Frigidaire/gas Range
Frigidaire FGFB66ECE Frigidaire/range
Frigidaire FGFB66ECF Frigidaire/range
Frigidaire FGFB66ECG Frigidaire/range
Frigidaire FGFB66ECH RANGE
Frigidaire FGFB66ECJ RANGE
Frigidaire FGFB66ECK RANGE
Frigidaire FGFB66ECM RANGE
Frigidaire FGFB66ECN RANGE
Frigidaire FGFB66ECP RANGE
Frigidaire FGFB66ECR RANGE
Frigidaire FGFB66ECS RANGE
Frigidaire FGFB68CBA Frigidaire/gas Range
Frigidaire FGFB68CBB Frigidaire/gas Range
Frigidaire FGFB68CBD Frigidaire/gas Range
Frigidaire FGFB68CBE Frigidaire/gas Range
Frigidaire FGFB68CQA Frigidaire/gas Range
Frigidaire FGFB68CQB Frigidaire/gas Range
Frigidaire FGFB68CQD Frigidaire/gas Range
Frigidaire FGFB68CQE Frigidaire/gas Range
Frigidaire FGFB68CSA Frigidaire/gas Range
Frigidaire FGFB68CSB Frigidaire/gas Range
Frigidaire FGFB68CSD Frigidaire/gas Range
Frigidaire FGFB68CSE Frigidaire/gas Range
Frigidaire FGFB74BJBA RANGE
Frigidaire FGFB74BJBB RANGE
Frigidaire FGFB75DBA Frigidaire/gas Range
Frigidaire FGFB75DBB Frigidaire/gas Range
Frigidaire FGFB75DBC Frigidaire/range
Frigidaire FGFB75DBE Frigidaire/range
Frigidaire FGFB75DBF Frigidaire/range
Frigidaire FGFB75DBG Frigidaire/gas Range
Frigidaire FGFB75DCA Frigidaire/gas Range
Frigidaire FGFB75DCB Frigidaire/range
Frigidaire FGFB75DCC Frigidaire/range
Frigidaire FGFB75DQA Frigidaire/gas Range
Frigidaire FGFB75DQB Frigidaire/gas Range
Frigidaire FGFB75DQC Frigidaire/range
Frigidaire FGFB75DQE Frigidaire/range
Frigidaire FGFB75DQF Frigidaire/range
Frigidaire FGFB75DQG Frigidaire/gas Range
Frigidaire FGFB75DSA Frigidaire/gas Range
Frigidaire FGFB75DSB Frigidaire/gas Range
Frigidaire FGFB75DSC Frigidaire/range
Frigidaire FGFB75DSE Frigidaire/range
Frigidaire FGFB75DSF Frigidaire/range
Frigidaire FGFB75DSG Frigidaire/gas Range
Frigidaire FGFB79GBA Frigidaire/range
Frigidaire FGFB79GBB GAS RANGE
Frigidaire FGFB79GBC GAS RANGE
Frigidaire FGFB79GBD GAS RANGE
Frigidaire FGFB79GBE GAS RANGE
Frigidaire FGFB79GBF GAS RANGE
Frigidaire FGFB79GCA Frigidaire/range
Frigidaire FGFB79GCB GAS RANGE
Frigidaire FGFB79GCD GAS RANGE
Frigidaire FGFB79GCE GAS RANGE
Frigidaire FGFB79GCG GAS RANGE
Frigidaire FGFB79GCH GAS RANGE
Frigidaire FGFB79GQA Frigidaire/range
Frigidaire FGFB79GSA Frigidaire/range
Frigidaire FGFB79GSB GAS RANGE
Frigidaire FGFB79GSC GAS RANGE
Frigidaire FGFB79GSD GAS RANGE
Frigidaire FGFB79GSE GAS RANGE
Frigidaire FGFB79GSF GAS RANGE
Frigidaire FGFB82DSA Frigidaire/range
Frigidaire FGFB86DBA Frigidaire/gas Range
Frigidaire FGFB86DBB Frigidaire/range
Frigidaire FGFB86DBC Frigidaire/range
  #2 (permalink)
Old 01-13-2012, 06:16 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for FRIGIDAIRE FGF379WJCA GAS, RANGE | AppliancePartsPros.com
Looks like you could replace the racks if you wanted to.
I know of no reliable way to re-coat the oven interior.
Clean off the rust with isopropyl alcohol.
Then coat the worn area with vegetable oil.
To get the racks sliding better do the same thing to their sides that ride on the oven rails.
You may have to re-new it every couple months or so.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Inside oven door jul Oven Repair (including Ranges and Cooktops) 0 10-16-2011 06:08 AM
Cracked inside oven door Peanuts Oven Repair (including Ranges and Cooktops) 2 05-05-2011 05:06 AM
oven glass cracked on inside dvalento Oven Repair (including Ranges and Cooktops) 3 03-24-2011 01:28 AM
Need to get inside oven door tcblankenship Oven Repair (including Ranges and Cooktops) 1 10-26-2010 09:09 AM
inside oven will not heat up ar.muncy Oven Repair (including Ranges and Cooktops) 0 04-20-2010 09:41 AM
