Recently, when this oven was set for preheat, the sequence seemed to start OK, then gas shuts off after a few minutes, and heat-up ceases. No error codes. Also tried setting bake temp, oven again sarts to heat but then get a temporary gas smell and heating once again shuts off. Broiler works fine.
I can see the ignitor glowing orange
Quote:the ignitor glowing orange If the ignitor IS glowing but there is no flame at the oven burner, the problem is either the ignitor or the oven gas valve. And yes, an ignitor can glow and still be defective. LINK > Frigidaire FGF379WECR Oven IgnitorLINK > FGF379WECR Oven Gas ValveOnly an amperage measurement of the ignitor circuit will pinpoint which might be responsible. The ignitor used on your model should draw 3.2 - 3.6 amps. Anything more or less and it is likely defective and needs to be replaced. If the amperage is within those tolerances but the valve is not releasing gas into the oven burner, the valve would be suspect. The ignitor is however the most common (~70-80%) troublemaker in such an ignition system. JMO Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~
