Discuss
How to replace bezel trim on Magic Chef oven
 in
I have the part I'm just not sure how to replace it. Do I just pull off the old
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to replace bezel trim on Magic Chef oven
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-03-2008, 02:53 PM
44556677oven 44556677oven is offline
Junior Member
44556677oven is on a distinguished road
Default How to replace bezel trim on Magic Chef oven
Model Number: 64hn-4tkvw   Brand: Magic Chef   Age: More than 10 years
I have the part I'm just not sure how to replace it. Do I just pull off the old cracked one and then push in the replacement? Are there clips to hold it in place?
And while I have the bezel off can I clean the woking parts for the knobs that control the tempature and time? What should I use to clean them?
Thanks very much
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-03-2008, 08:25 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The bezel is self adhesive. Pull off the old one, remove the protective paper from the new one and push it in.
I do not think it needs any cleaning.
- Here are the break down diagrams for the Magic Chef range Model 64HN-4TKVW
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-24-2008, 06:06 PM
vindivixon vindivixon is offline
Junior Member
vindivixon is on a distinguished road
Default
I used "Simple Green" to clean just about everything on myTappan Deluxe.
I even got the clock to start running, by using Q-tips with Simple Green in between the gears...it now runs great!! The red glass bezels replace the white plastic rings around the gas knobs. I have 4 beautiful bezels that I may not be able to use, if I don't get a pattern/diagram how they're supposd to be hooked up. We're making our Tappan Deluxe in the Tappan Deluxe with the glass bezels...husband loves those bezels!! If anyone has a diagram of how the switches go, and the general lay-out of the wiring under the top of the stove, PLEASE...send it to me.....
I have a gorgeous 1937 Magic Chef I need to sell, so I have the space to put the Tappan in.
She's a beauty...only asking $600 for her. I'll gladly send pics to whomever may be interested.
  #4 (permalink)
Old 07-18-2008, 11:26 AM
dennphill dennphill is offline
Junior Member
dennphill is on a distinguished road
Default
Good luck.
Gene -
I think you are my savior! I have just spent an hour or more on Chat with a fine Service Rep at Appliance Parts Pros dot com, trying to help me figure out how to replace the bezel they just sold me to replace one with totally worn off white lettering. The reply above shows a stove - not exactly mine - but with a similar looking control panel and bezel, so I'd like to jump in and ask you for assistance with removing the small STOP/CLEAR button on the upper left side of the bezel. (In the diagram, I think this button is item 11.) I have an older Magic Chef ceramic top range oven - it's a "drop-in" unit - with model number 58HK-6TXW. There is a knurled knob on the right side of the bezel where it says < SET >. This just pulls off. The smaller button on the left, where it says STOP/CLEAR just won't pull off. (It won't twist off either.) Can you help? How do I get this STOP/CLEAR button off? Thanks, Dennis
  #5 (permalink)
Old 07-18-2008, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by dennphill View Post
...The smaller button on the left, where it says STOP/CLEAR just won't pull off. (It won't twist off either.) Can you help? How do I get this STOP/CLEAR button off? ...
Hi Dennis,
The knob on the left side is not like a regular knob. Actually this is a button which plugs into the control board.
You have very carefully pull it straight out. Be advised it's very fragile and if it breaks than the piece left inside the control board almost not possible to remove.
__________________
  #6 (permalink)
Old 07-23-2008, 08:12 AM
Junior Member
Default
Hi Dennis,
Gene - Thanks for the quick reply. It was a confirmation of what I suspected, but I'd tried very hard to pull on it already...and twisting it (if it was screwed on) obviously wasn't working either. Sorry for the delay, but I waited a day or so...worked up courage...and yesterday I placed two common tip screwdrivers with small wedges underneath to give equal leverage, and then I tried to pull this part straight up. I think I applied a LOT of pressure...the whole assembly (bezel and underlying control/clock unit) seemed to raise up an 1/8 inch or so but with absolutely NO movement outward on the button (other than the 1/8 play it already has when pushed to reset and which allowed the screwdriver tips underneath it and the bezel). I am truly worried now about breaking it off. Any ideas?
If not, I guess I will just "gorilla it" again but harder until I get it out or it breaks off. I really am afraid if it breaks that I cannot get a replacement control unit for this old stove and I may end up having to buy another drop-in range. Thanks, in advance, for any advice and your time and attention. V/r, Dennis Phillips 703-799-7452
  #7 (permalink)
Old 07-23-2008, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dennis,
Turn the power to the range off. Try to inject a few drops of water along the shaft of the button to lubricate it.
__________________
  #8 (permalink)
Old 07-26-2008, 04:04 AM
Junior Member
Default
Thanks, Gene -
Good idea...don't know if it worked (I tried it and waited an hour or so) or if the pressure I applied just caused it to finally come off. I used a small pry bar on one side, and a claw hammar on the other, trying to keep pressure even on both sides of the button. When it came off, it did so with a LOUD pop, and flew across the kitchen. I was certain I had busted it, but on inspection the button was intact. I took the old bezel off, and after cleaning thoroughly, placed on the new bezel on and replaced the button (went on much easier than it had come off!) and the right side knob. Looks much better now. Again, thanks for the advice. Boy, this was a lot of effort over a silly little button! Nice site...I appreciate your patience. Just (also) replaced a 3-4 year old Frigidaire dishwasher lower rack where the rubberized covering had worn and allowed some unsightly rust to bubble up around where the rubber was worn - the part was ordered and appeared UPS in only 3 days! AppliancePartsPros delivers quickly!
  #9 (permalink)
Old 07-26-2008, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Dennis,
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to replace Clock Controller on Magic Chef jswanz Oven Repair (including Ranges and Cooktops) 3 01-04-2008 08:36 AM
Magic chef oven 6498vrv michaelman31 Oven Repair (including Ranges and Cooktops) 5 12-04-2007 07:03 PM
Magic Chef Oven Not Turning On COLORICAN Oven Repair (including Ranges and Cooktops) 2 11-26-2007 07:40 AM
Magic Chef oven top element not working charlotte Oven Repair (including Ranges and Cooktops) 0 11-25-2007 09:42 AM
Magic Chef gas oven won't light koohgar Oven Repair (including Ranges and Cooktops) 10 10-17-2007 02:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
