| » Oven igniter clicks twice but oven does not light |
Model Number: SF362LXSY0 Brand: Whirlpool Age: 1 - 5 years
Not only does the oven not work but niether does the broiler. I think I need a part that is common to both the broiler and the oven. Could both igniters be bad at the same time? I checked but no error code. The model number is SF362LXSY0.
were both bake +broil working +both stopped working at same time?if so check for 110 volts coming to safety valve.or remove wires and check for continuity across contactson valve ,could terminal b+c , if no power of 110 volts it may be board, if there is power it may be valve.there sholud be continuity across b+c
__________________
| Display Modes | |
| jennair oven display goes out and oven just clicks | p0300misfire | Oven Repair (including Ranges and Cooktops) | 0 | 12-20-2009 03:49 PM |
| Igniter clicks but doesn't always light | SVC | Oven Repair (including Ranges and Cooktops) | 0 | 09-02-2009 07:14 AM |
| GE Oven Igniter lights but oven takes forever to light up | Byl | Oven Repair (including Ranges and Cooktops) | 3 | 08-18-2009 10:47 AM |
| gas oven igniter glows orange but won't light | johngi | Oven Repair (including Ranges and Cooktops) | 1 | 06-22-2009 08:33 PM |
| oven igniter starts gas until u release the start then it gas shuts off but not light | bradk36 | Oven Repair (including Ranges and Cooktops) | 1 | 01-22-2008 04:16 PM |
