| » Thermador Bake Element Replacment Issue |
Model Number: CMT231 Brand: Thermador Age: More than 10 years
I have a CMT231 Oven and replaced the bake element and it does not heat. I uninstalled and rechecked the wires which seem to be fine. After re-installing the bake element still does not heat. Can someone point me in the right direction. The part came from appliancepartspros.com based on my model number. Is the new element not compatible for some reason or is there and issue with control board or an internal fuse that needs replacing?
I would check to see if I had voltage to the element with a multimeter.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
Could you outline path if there is voltage or no-voltage, since I do not have a meter right now. This would help me to understand potential issues. Thanks.
| Display Modes | |
| Maytag Gemini Bake Element Issue | iruntoo | Oven Repair (including Ranges and Cooktops) | 5 | 07-20-2012 06:19 PM |
| Bake Element Issue | Saltin | Oven Repair (including Ranges and Cooktops) | 1 | 12-19-2009 01:45 PM |
| Broil Element Replacment Bent | rob5 | Oven Repair (including Ranges and Cooktops) | 4 | 11-13-2009 07:52 AM |
| Oven bake/broil not working after bake element replacement | J Justin | Oven Repair (including Ranges and Cooktops) | 1 | 11-05-2009 04:36 PM |
| Thermador dual fuel bake/heating element replaced, still not working | socalmat | Oven Repair (including Ranges and Cooktops) | 1 | 10-28-2009 01:03 PM |
