Model: RF3020XG no burners heat up, but the indicator light does. The oven does not heat and the indicator light does not come on. It all worked fine two days ago. Any suggestions?
Check the voltage to the range, should be 220-240 Vac.
I had an electrician come and sure enough, there was a problem with the wiring. Thank you so much! I don't have to buy a stove now!!
Your welcome, Glad you got it repaired.
