Our range does not hold it's temperature properly. If I set it to 450 degrees it will vary from 200 to 300 (Indicated by thermometer). There are no error messages on the control. I replaced the thermistor (temperature sensor) with no change of performance. Sometimes when I set the temperature, it will come up close to the setting but then over time it will slowly drop down.
Does this sound like the control it self and if so what is the part number?
Thank you
Originally Posted by: Jay Potter Our range KitchenAid Model KERI203PBS2 does not hold it's temperature properly. If I set it to 450 degrees it will vary from 200 to 300 degrees as Indicated by thermometer. There are no error messages on the control. I replaced the thermistor (temperature sensor) with no change of performance. Sometimes when I set the temperature, it will come up close to the setting but then over time it will slowly drop down.
Does this sound like the control itself and if so what is the part number?
How should I best proceed to fix this unit?
Thank you Our range KitchenAid Model KERI203PBS2 does not hold it's temperature properly. If I set it to 450 degrees it will vary from 200 to 300 degrees as Indicated by thermometer. There are no error messages on the control. I replaced the thermistor (temperature sensor) with no change of performance. Sometimes when I set the temperature, it will come up close to the setting but then over time it will slowly drop down. Does this sound like the control itself and if so what is the part number? How should I best proceed to fix this unit? Thank you
