Discuss
F9 Error Code - Can't get it to stop beeping
 in
Hello, Last night I attempted to set my range for a 2 hour self clean cycle. Fridgidaire model BFEF374CS3. When
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F9 Error Code - Can't get it to stop beeping
  #1 (permalink)
Old 01-09-2012, 05:14 PM
Junior Member
syarechewski is on a distinguished road
Default F9 Error Code - Can't get it to stop beeping
Model Number: BFEF374CS3   Brand: Frigidaire   Age: 5 - 10 years
Hello,
Last night I attempted to set my range for a 2 hour self clean cycle. Fridgidaire model BFEF374CS3. When I finsihed setting the clock, I would normally hear the lock set itself. This time I could hear the clock kinda of clicking (trying to rotate to lock the door but it did not lock (sounded like a solenoid that isn't working).
After that it flashed betwed F9 and dr and won't stop beeping. I unpugged it last night but when I pliugged it back in tonight, it simply started the process over again. The lock tried to set (unsuccessfully) and it begain beeping with the error codes flashing.
I must also say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. I eventually unplugged and plugged it back in enough times that the lock moved far enough (maybe to the 1:30 position - normally sits as 12:00 position when unlocked).
Thanks for any advice anyone can provide!
Related Models
Frigidaire BFEF374EB1 Frigidaire Canada/electric Range
Frigidaire BFEF374EB2 Frigidaire Canada/electric Range
Frigidaire BFEF374EB3 Frigidaire/range
Frigidaire BFEF374EB4 Frigidaire Canada/electric Range
Frigidaire BFEF374ES1 Frigidaire Canada/electric Range
Frigidaire BFEF374ES2 Frigidaire Canada/electric Range
Frigidaire BFEF374ES3 Frigidaire/range
Frigidaire BFEF374ES4 Frigidaire Canada/electric Range
Frigidaire BFEF374FC1 Frigidaire Canada/electric Range
Frigidaire BFEF374JIS1 ELECTRIC RANGE
Frigidaire BFES368EC1 Frigidaire Canada/electric Range
Frigidaire BFES368EC2 Frigidaire Canada/electric Range
Frigidaire BFES368EC3 Frigidaire/range
Frigidaire BFES368EC4 Frigidaire/range
Frigidaire BFES368EC5 Frigidaire Canada/electric Range
Frigidaire BFES368EC6 Frigidaire Canada/electric Range
Frigidaire BFES368EC7 ELECTRIC RANGE
Frigidaire BFES368ES1 Frigidaire/electric Range
Frigidaire BFES368ES2 Frigidaire Canada/electric Range
Frigidaire BFES368ES3 Frigidaire Canada/electric Range
Frigidaire BFES368ES4 Frigidaire Canada/electric Range
Frigidaire BFES368ES5 Frigidaire/range
Frigidaire BFES368ES6 FRIGIDAIRE/RANGE
Amana BFF105 REF - BOTTOM MOUNTS
Amana BFF105L REF - BOTTOM MOUNTS
Amana BFF125 REF - BOTTOM MOUNTS
Amana BFF125L REF - BOTTOM MOUNTS
Amana BFF98 REF - BOTTOM MOUNTS
Amana BFF98L REF - BOTTOM MOUNTS
Frigidaire BFFC05M2MW0 FREEZER
Amana BFFS105 REF - BOTTOM MOUNTS
Amana BFFS105L REF - BOTTOM MOUNTS
Amana BFFS125 REF - BOTTOM MOUNTS
Amana BFFS125L REF - BOTTOM MOUNTS
Amana BFFS98 REF - BOTTOM MOUNTS
Amana BFFS98L REF - BOTTOM MOUNTS
Frigidaire BFHS2611LM0 REFRIGERATOR
Frigidaire BFHS2611LM1 REFRIGERATOR
Frigidaire BFHS2611LM2 FRIGIDAIRE/REFRIGERATOR
Whirlpool BFR101 Air-conditioner/heat pump
Whirlpool BFR1011 Air-conditioner/heat pump
Amana BFR105 REF - BOTTOM MOUNTS
Amana BFR105L REF - BOTTOM MOUNTS
Whirlpool BFR121 Air-conditioner/heat pump
Whirlpool BFR183 HI EFFICIENCY 18,000 BTU/HR AIR CONDITIONER
Whirlpool BFR243 Air-conditioner/heat pump
Whirlpool BFR51 Air-conditioner/heat pump
Whirlpool BFR61 Air-conditioner/heat pump
Whirlpool BFR81 Air-conditioner/heat pump
Amana BFR95 REF - BOTTOM MOUNTS
Amana BFR95L REF - BOTTOM MOUNTS
Whirlpool BFRE123 Air-conditioner/heat pump
Whirlpool BFRE183 Air-conditioner/heat pump
Whirlpool BFRE81 Air-conditioner/heat pump
Whirlpool BFRH123 Air-conditioner/heat pump
Whirlpool BFRH183 Air-conditioner/heat pump
Whirlpool BFRH81 Air-conditioner/heat pump
Amana BG18VL REF - BOTTOM MOUNTS
Amana BG18VW REF - BOTTOM MOUNTS
Amana BG20T2L REF - BOTTOM MOUNTS
Amana BG20T2W REF - BOTTOM MOUNTS
Amana BG20TL REF - BOTTOM MOUNTS
Amana BG20TW REF - BOTTOM MOUNTS
Amana BG21V1C REF - BOTTOM MOUNTS
Amana BG21V1W REF - BOTTOM MOUNTS
Amana BG21VC REF - BOTTOM MOUNTS
Amana BG21VL REF - BOTTOM MOUNTS
Amana BG21VW REF - BOTTOM MOUNTS
 BG8000ER Air Conditioner
Frigidaire BGBD2432KB0 DISHWASHER
Frigidaire BGBD2432KF0 DISHWASHER
Frigidaire BGBD2432KW0 DISHWASHER
Roper BGC430WB0 Range (gas)*
Frigidaire BGEF3032KBA ELECTRIC RANGE
Frigidaire BGEF3032KBB ELECTRIC RANGE
Frigidaire BGEF3032KBC ELECTRIC RANGE
Frigidaire BGEF3032KWA ELECTRIC RANGE
Frigidaire BGEF3032KWB ELECTRIC RANGE
Frigidaire BGEF3032KWC ELECTRIC RANGE
Frigidaire BGEF3042KFA ELECTRIC RANGE
Frigidaire BGEF3042KFB ELECTRIC RANGE
Frigidaire BGEF3042KFC ELECTRIC RANGE
Frigidaire BGEF3042KFD ELECTRIC RANGE
Frigidaire BGEF3044KFA ELECTRIC RANGE
Frigidaire BGEF3044KFB ELECTRIC RANGE
Maytag BGFIM18E5 UNDERCOUNTER BUILT IN ICE MAKER
Frigidaire BGGF3031KBA GAS RANGE
Frigidaire BGGF3031KBB GAS RANGE
Frigidaire BGGF3031KBC GAS RANGE
Frigidaire BGGF3031KBD GAS RANGE
Frigidaire BGGF3031KBE GAS RANGE
Frigidaire BGGF3031KBF GAS RANGE
Frigidaire BGGF3031KBG GAS RANGE
Frigidaire BGGF3031KBH GAS RANGE
Frigidaire BGGF3031KWA GAS RANGE
Frigidaire BGGF3031KWB GAS RANGE
Frigidaire BGGF3031KWC GAS RANGE
Frigidaire BGGF3031KWD GAS RANGE
Frigidaire BGGF3031KWE GAS RANGE
Frigidaire BGGF3031KWF GAS RANGE
Frigidaire BGGF3031KWG GAS RANGE
Frigidaire BGGF3031KWH GAS RANGE
Frigidaire BGGF3041KFA GAS RANGE
Frigidaire BGGF3041KFB GAS RANGE
Frigidaire BGGF3041KFC GAS RANGE
Frigidaire BGGF3041KFD GAS RANGE
Frigidaire BGGF3041KFE GAS RANGE
Frigidaire BGGF3042KFA GAS RANGE
Frigidaire BGGF3042KFB GAS RANGE
Frigidaire BGGF3042KFC GAS RANGE
Frigidaire BGGF3042KFD GAS RANGE
Frigidaire BGGF3042KFE GAS RANGE
  #2 (permalink)
Old 01-10-2012, 10:15 AM
Banned
Chris_Polk is on a distinguished road
Default F9 error code
Typically when it comes to any F9 series code for this manufacturer the following needs to be done by a service professional:
1. Check the wiring between EOC and lock motor micro switch.
2. Replace the motor door latch assembly.
3. Check for binding of the latch cam, lock motor rod and lock motor cam.
4. Check to see if lock motor coil is open. If open, replace lock motor assembly.
5. Lock motor continuously runs- if micro switch is open, replace lock motor assembly
6. (F92, 93, 94 and 95) check oven door light switch- if open, replace switch.
7. If all situations above do not solve problem, replace EOC.
Please contact Frigidaire or use their online directory at www.Frigidaire.com/servicelocator to schedule an appointment.
  #3 (permalink)
Old 01-10-2012, 10:32 AM
Junior Member
Default
Thanks Chris, appreciate the quick response!
  #4 (permalink)
Old 02-06-2012, 03:23 PM
Junior Member
maryd2473 is on a distinguished road
Default
I have to same problem, but until a repair man can come out...how do i use my oven?
  #5 (permalink)
Old 04-30-2013, 07:50 PM
Junior Member
nikkimarie is on a distinguished road
Default F9 Error Code - Solution
You may have to unplug the oven (or disable to breaker) until it cools. I had to tug a bit to get the door to open. Once it was open, there is a black button in the top right corner of the stove that senses the door being open/shut. Hold that button down and turn the silver door lock in the center counter clockwise until it is straight up. This will tell the oven that the door is no longer locked and resets the code. You should not hear the beeping after that.
  #6 (permalink)
Old 11-12-2014, 09:09 AM
Junior Member
Rebecca.diane is on a distinguished road
Smile Thank you so much.
It was a bit tough to get mine to turn but once it did it worked. Turn until you hear the click and the light goes off! Thank you so much!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F5 error code and beeping on bake, clean, and broil ghmoore Oven Repair (including Ranges and Cooktops) 1 12-23-2011 09:42 AM
F2 error code, constant beeping Henry J Washer Repair 0 12-07-2011 01:38 PM
Mini oven board beeping with no error code Marty7w Oven Repair (including Ranges and Cooktops) 0 06-06-2011 05:35 PM
F-7 error code magic chef started beeping this A boblf Oven Repair (including Ranges and Cooktops) 6 05-28-2009 02:41 AM
F1 Error Code - Continuous Beeping!! Derrick Cote Oven Repair (including Ranges and Cooktops) 9 10-06-2008 05:27 PM
