Discuss
Power Loss Message on JennAir Oven
 in
Hi, Our JennAir Stove says Power Loss on the touch panel. The time on the stove is incorrect but does
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Power Loss Message on JennAir Oven
  #1 (permalink)
Old 01-08-2012, 05:01 AM
Junior Member
pellcity1014 is on a distinguished road
Default Power Loss Message on JennAir Oven
Model Number: JGS9900BDS   Brand: Jenn-Air   Age: 1 - 5 years
Our JennAir Stove says Power Loss on the touch panel. The time on the stove is incorrect but does change minute by minute. We have tried the following:
1-Replaced the electrical panel with absolutely no change in the message.
2-Checked the voltage on the outlet. It is fine.
3-Tried pressing the cancel button and also tried holding the 2 buttons for 3 seconds that are supposed to "unlock" the control panel.
I guess I'm wondering if there is any other way to reset this oven. Obviously is must have power or it would not be able to display this message or display an incorrect time.
Please, any suggestions....even if the suggestion is buy a new stove...
If I can fix the problem that is great...but at this point I don't want to buy any more expensive parts unless it will fix the problem.
Thanks for your help
Related Models
Jenn-Air JGS9900BDS RANGE- S/C S/I DDRAFT GAS
Maytag JGS9900BDS15 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900BDS16 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDB00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDF00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDR00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS00 30" SLIDE-IN DOWNDRAFT RANGE GAS ON GLASS
Maytag JGS9900CDS01 30" SLIDE IN GAS ON GLASS DOWNDRAFT RANGE
Jenn-Air JGS9900CDS02 30" SLIDE-IN GAS ON GLASS DOWNDRAFT RANGE
General Electric JGSC07GEJ1 Electric range
General Electric JGSC07GEJ2 Gas range
General Electric JGSC08GEK1 Electric range
General Electric JGSC08GEK3 Electric range
General Electric JGSC12GEP1 Gas range
General Electric JGSC12GER1BG Gas range
General Electric JGSC12GET1BG Gas range
General Electric JGSC12GEV1BG Gas range
General Electric JGSP10GEK1 Electric range
General Electric JGSP10GEK2 Gas range
General Electric JGSP10GEK3 Electric range
General Electric JGSP20GEP1 Electric range
General Electric JGSP20GEP2 Gas range
General Electric JGSP20GER1BG Gas range
General Electric JGSP20GER2BG Gas range
General Electric JGSP20GER3BG Gas range
General Electric JGSP20GET1BB Gas range
General Electric JGSP21GEP1 Gas range
General Electric JGSP21GEP2 Gas range
General Electric JGSP21GER1WH Gas range
General Electric JGSP21GER2WH Gas range
General Electric JGSP21GER3WH Gas range
General Electric JGSP21WET1WW Gas range
General Electric JGSP22GEV1BB Gas range
General Electric JGSP22GEV3BB Gas range
General Electric JGSP23BEW1BB Gas range
General Electric JGSP23BEY1BB Gas range
General Electric JGSP23BEY2BB Gas range
General Electric JGSP23BEY3BB Gas range
General Electric JGSP23BEY4BB Gas range
General Electric JGSP23BEY5BB Gas range
General Electric JGSP23CEY1CC Gas range
General Electric JGSP23WEV1WW Gas range
General Electric JGSP23WEV2WW Gas range
General Electric JGSP23WEV5WW Gas range
General Electric JGSP23WEV6WW Gas range
General Electric JGSP23WEW1WW Gas range
General Electric JGSP23WEY1WW Gas range
General Electric JGSP23WEY2WW Gas range
General Electric JGSP23WEY3WW Gas range
General Electric JGSP23WEY5WW Gas range
General Electric JGSP23WEY6WW Gas range
General Electric JGSP23WEY7WW Gas range
General Electric JGSP28BEK1BB Gas range
General Electric JGSP28BEK2BB Gas range
General Electric JGSP28BEK3BB Gas range
General Electric JGSP28BEK4BB Gas range
General Electric JGSP28BEK5BB GAS RANGE
General Electric JGSP28CEK1CC Gas range
General Electric JGSP28CEK2CC Gas range
General Electric JGSP28CEK3CC Gas range
General Electric JGSP28CEK4CC Gas range
General Electric JGSP28CEK5CC GAS RANGE
General Electric JGSP28DEN1BB GAS RANGE
General Electric JGSP28DEN1CC GAS RANGE
General Electric JGSP28DEN1WW GAS RANGE
General Electric JGSP28DEN2BB GAS RANGE
General Electric JGSP28DEN2CC GAS RANGE
General Electric JGSP28DEN2WW GAS RANGE
General Electric JGSP28DEN3BB GAS RANGE
General Electric JGSP28DEN3CC GAS RANGE
General Electric JGSP28DEN3WW GAS RANGE
General Electric JGSP28SEK1SS Gas range
General Electric JGSP28SEK2SS Gas range
General Electric JGSP28SEK3SS Gas range
General Electric JGSP28SEK4SS Gas range
General Electric JGSP28SEK5SS GAS RANGE
General Electric JGSP28SEN1SS GAS RANGE
General Electric JGSP28SEN2SS GAS RANGE
General Electric JGSP28SEN3SS GAS RANGE
General Electric JGSP28SEN4SS GAS RANGE
General Electric JGSP28WEK1WW Gas range
General Electric JGSP28WEK2WW Gas range
General Electric JGSP28WEK3WW Gas range
General Electric JGSP28WEK4WW Gas range
General Electric JGSP28WEK5WW GAS RANGE
General Electric JGSP30GEP1 Electric range
General Electric JGSP30GEP2 SLIDE-IN RANGE, GAS
General Electric JGSP30GEP4BG Gas range
General Electric JGSP30GEP5BG Electric range
General Electric JGSP30GER1BG Gas range
General Electric JGSP30GER2BG Gas range
General Electric JGSP30GER3BG Gas range
General Electric JGSP30GET1BB Gas range
General Electric JGSP31GEP1 Gas range
General Electric JGSP31GEP4 Gas range
General Electric JGSP31GEP5WG Gas range
General Electric JGSP31GEP6WG Electric range
General Electric JGSP31GER1WG Gas range
General Electric JGSP31GER2WG Gas range
General Electric JGSP31GER3WG Gas range
General Electric JGSP31WET1WW Gas range
General Electric JGSP32GEV1BB Gas range
General Electric JGSP32GEV2BB Gas range
General Electric JGSP32GEV3BB Gas range
General Electric JGSP33WEV1WW Gas range
General Electric JGSP33WEV2WW Gas range
General Electric JGSP33WEV3WW Gas range
General Electric JGSP33WEV4WW Gas range
General Electric JGSP33WEV5WW Gas range
General Electric JGSP33WEV6WW Gas range
General Electric JGSP33WEV7WW Gas range
General Electric JGSP40AES1AG Gas range
General Electric JGSP40AES2AG Gas range
General Electric JGSP40AET1AA Gas range
General Electric JGSP44AEV1AA Gas range
General Electric JGSP44AEV2AA Gas range
General Electric JGSP44AEV3AA Gas range
General Electric JGSP44AEY1AA Gas range
General Electric JGSP44BEY1BB Gas range
General Electric JGSP44BEY2BB Gas range
  #2 (permalink)
Old 05-15-2014, 08:01 PM
Junior Member
forcamoro is on a distinguished road
Default
Did you ever resolve your issue with the power loss code? I am asking because I have the same problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
JennAir Built in loss of power how5995 Microwave Repair 0 10-17-2011 04:31 PM
Oven Not Working After Power Loss Fatjack Oven Repair (including Ranges and Cooktops) 0 06-15-2011 04:28 PM
Loss of All Power/Upper Panel digrmi Oven Repair (including Ranges and Cooktops) 0 01-23-2011 09:31 AM
whirlpool microwave power loss alikatmack Microwave Repair 0 01-11-2010 06:23 PM
No power to Oven after Power Loss to home mac21 Oven Repair (including Ranges and Cooktops) 9 06-16-2009 08:23 PM
