| » "Err" message when trying to Bake above 260 |
Model Number: KGRT507B Brand: Kitchen Aid Age: 5 - 10 years
After being gone for a week our Kitchen Aid oven will not work when setting the BAKE temperature above 260 degrees. It gives an "Err" message instead. We've tried unplugging it for several minutes and it will heat up if the temperature is set at 260 degrees or lower. We inherited the stove when we bought our house back in March so I may be underestimating the age. Any ideas??
Somehow your oven is set to cook in Celsius instead of Fahrenheit.
To switch back to Fahrenheit open the oven door, then press and hold BROIL for 5 sec or until "F°" will appear on the display. - For the future references here are the break down diagrams for the Kitchen Aid range Model KGRT507BAL1 Good luck. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I'm glad you were able to fix it.
Happy New year! Gene.
__________________
I never worked so hard to solve such a simple problem.
The solution appears to be the same for my KitchenAid (kgsc308Lss0) convection gas oven. Symptoms were exactly the same, and now I can set temp setppoints above 260 again. A million thanks!!!!….. and a hot Easter meal if you’re in the Denver area. Ed |
Hi Ed,
Happy Easter! I'm glad you were able to fix it. Gene.
__________________
My wife just called the local repair man and he said the service charge would be $50 and if the main board had went out it would be $200. So thanks to the internet and honest experts like yourself, we saved a lot so Thank you very much.
We're glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
__________________
| Display Modes | |
| "Door" message on display, unit won't start | RichardJ | Microwave Repair | 6 | 07-15-2011 03:32 PM |
| Mocrowave gives "door" error message | swanson | Microwave Repair | 1 | 07-15-2011 10:27 AM |
| Bosch Nexxt 6300 "clogged drain" message | spurcell | Washer Repair | 3 | 10-25-2009 01:38 PM |
| GE Profile Harmony "Close the Lid" message fix | fifty7kevie | Washer Repair | 0 | 02-25-2008 10:41 AM |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 06:36 PM |
