Help instructions for replacing the Broiler inginter. Broiler does not ingine...everything else is fine. I assume it is the ingiter.
Originally Posted by: Peter Perry Help instructions for replacing the Broiler iginiter. Broiler does not ingine...everything else is fine. I assume it is the igniter. Is there a diagram required...looks pretty simple but the wires attached to the igniter seem to suggest that I have to dig into the top somehow. Is the necessary access from the oven itself?
