Discuss
Magic Chef oven won't get hot
 in
Hello, Our Magic Chef oven won't get hot enough to bake. It reaches about 200 degrees at most (Not thermometer
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic Chef oven won't get hot
  #1 (permalink)
Old 07-08-2009, 03:59 PM
Junior Member
zipperator is on a distinguished road
Question Magic Chef oven won't get hot
Model Number: 64FA-3CKXW   Brand: Magic Chef   Age: More than 10 years
Hello,
Our Magic Chef oven won't get hot enough to bake. It reaches about 200 degrees at most (Not thermometer checked), but the broiler was working when I tested it yesterday. Stove top works just fine. This unit, I think, was the original appliance with our home when it was built in 1989. Has anyone had this problem, and do you know how much it would be to fix? Should we just invest in a new unit?
Thank you!!!!!
Ads By Google
Related Models
Magic Chef 64FA-3CKXW Range - S/c S/i Gas
Magic Chef 64FB-3CKW Range - S/c S/i Gas
Magic Chef 64FK-3CKX Range - S/c S/i Gas
Magic Chef 64FK-3CKXW Range - S/c S/i Gas
Magic Chef 64FN-3CKVW Range - S/c S/i Gas
Magic Chef 64FN-3CKW Range - S/c S/i Gas
Magic Chef 64FN-3CKX Range - S/c S/i Gas
Magic Chef 64FN-3CKXW Range - S/c S/i Gas
Magic Chef 64FY-3CKW Range - S/c S/i Gas
Magic Chef 64FY-3CKX Range - S/c S/i Gas
Magic Chef 64FY-3CKXW Range - S/c S/i Gas
Magic Chef 64H-4TKVW Range - S/c S/i Gas
Magic Chef 64H-4TKXW Range - S/c S/i Gas
Magic Chef 64HA-4TKVW Range - S/c S/i Gas
Magic Chef 64HA-4TKXW Range - S/c S/i Gas
Magic Chef 64HK-4TKXW Range - S/c S/i Gas
Magic Chef 64HN-4TKVW Range - S/c S/i Gas
Magic Chef 64HN-4TKXW Range - S/c S/i Gas
Hoover 65
Amana 650.000 Mwave - Family Size (60 Hz)
Amana 650.001 Range - S/c S/i Ddraft Gas
Magic Chef 6500PRA Range - S/i Std Ele
Magic Chef 6500PRL
Magic Chef 6500PRS
Magic Chef 6500PRW Range - S/i Std Ele
Magic Chef 6500SRS Range - S/i Std Ele
Hoover 651 Frigidaire/electric Range
Amana 651.000 Range - S/c S/i Ddraft Gas
Amana 651.001 Range - S/c S/i Ddraft Gas
Amana 651.002 Range - S/c S/i Ddraft Gas
Amana 651.003 Range - S/c S/i Ddraft Gas
Amana 651.004 Range - S/c S/i Ddraft Gas
Amana 651.006 Range - S/c S/i Ddraft Gas
Kenmore 651.89918100  WRINGER WASHER
Admiral 651AH Range - S/c F/s Ele
Admiral 651WH Range - S/c F/s Ele
Admiral 653AH-HV Range - F/s Std Ele
Admiral 653AH-V Range - F/s Std Ele
Admiral 653AJ-HV Range - F/s Std Ele
Admiral 653AJ-V Range - S/c F/s Ele
Admiral 653AJ-V-CX Range - F/s Std Ele
Admiral 653WH-HV Range - F/s Std Ele
Admiral 653WH-V Range - F/s Std Ele
Admiral 653WJ-HV Range - F/s Std Ele
Admiral 653WJ-V Range - S/c F/s Ele
Admiral 653WJ-V-CX Range - F/s Std Ele
Admiral 654AD-HVW Range - F/s Std Ele
Admiral 654AG-HVW Range - F/s Std Ele
Admiral 654AH-ELVW Range - F/s Cont Clean Ele
Admiral 654AH-EVW Range - F/s Std Ele
Admiral 654AH-EW Range - F/s Std Ele
Admiral 654HG-HVW
Admiral 654WD-HVW Range - F/s Std Ele
Admiral 654WG-HVW Range - F/s Std Ele
Admiral 654WH-ELVW Range - F/s Cont Clean Ele
Admiral 654WH-ELW Range - F/s Cont Clean Ele
Admiral 654WH-EW Range - F/s Std Ele
Magic Chef 6551WRA Range - S/i Std Ele
Magic Chef 6551WRW Range - S/i Std Ele
Magic Chef 6551WUA Range - S/i Std Ele
Magic Chef 6551WUB Range - S/i Std Ele
Magic Chef 6551WUW Range - S/i Std Ele
Magic Chef 6551XRA Range - S/i Std Ele
Magic Chef 6551XRL
Magic Chef 6551XRS
Magic Chef 6551XRW Range - S/i Std Ele
Magic Chef 6551XUA Range - S/i Std Ele
Magic Chef 6551XUB Range - S/i Std Ele
Magic Chef 6551XUW Range - S/i Std Ele
Admiral 655AH-CVW Range - F/s Std Ele
Admiral 655WH-CVW Range - F/s Std Ele
Admiral 656AH-EHVW Range - F/s Std Ele
Admiral 656HH-EHVW Range - F/s Std Ele
Admiral 656WH-EHVW Range - F/s Std Ele
Maytag 65C Dryer - Gas
Magic Chef 65HA-1 Range - S/i Std Ele
Magic Chef 65HA-3W Range - S/i Std Ele
Magic Chef 65HA-3X Range - S/i Std Ele
Magic Chef 65HN-1 Range - S/i Std Ele
Magic Chef 65HN-3W Range - S/i Std Ele
Magic Chef 65HN-3X Range - S/i Std Ele
Hoover 66
Admiral 663AH-CV Range - S/c F/s Ele
Admiral 663WH-CV Range - S/c F/s Ele
Kenmore 665.1330590  COMPACTOR
Kenmore 665.1336580  TRASH COMPACTOR
Kenmore 665.1336581  TRASH COMPACTOR/
Kenmore 665.1336582  COMPACTOR
Kenmore 665.1338550  TRASH COMPACTOR
Kenmore 665.1338580  TRASH COMPACTOR
Kenmore 665.1338581  TRASH COMPACTOR
Kenmore 665.1338582  COMPACTOR
Kenmore 665.1339580  COMPACTOR
Kenmore 665.1339581  COMPACTOR
Kenmore 665.1340590  COMPACTOR
Kenmore 665.1340591  COMPACTOR
Kenmore 665.1340592  COMPACTOR
Kenmore 665.1340593  COMPACTOR
Kenmore 665.1340594  COMPACTOR
Kenmore 665.1350190  COMPACTOR
Kenmore 665.1350191  COMPACTOR
Kenmore 665.1350192  COMPACTOR
Kenmore 665.1350193  COMPACTOR
Kenmore 665.1350194  COMPACTOR
Kenmore 665.1350195  COMPACTOR
Kenmore 665.1350196  COMPACTOR
Kenmore 665.1350590  COMPACTOR
Kenmore 665.1350591  COMPACTORS
Kenmore 665.1350592  COMPACTOR
Kenmore 665.1350593  COMPACTOR
Kenmore 665.1350594  COMPACTORS
Kenmore 665.1350595  COMPACTOR
Kenmore 665.1350596  COMPACTOR
Kenmore 665.1358550  TRASH COMPACTOR
Kenmore 665.1358551  TRASH COMPACTOR
Kenmore 665.13601790  COMPACTOR
Kenmore 665.13603000  COMPACTORS
Kenmore 665.13604000  COMPACTORS
Kenmore 665.13605790  COMPACTOR
Kenmore 665.13608790  COMPACTOR
  #2 (permalink)
Old 07-09-2009, 01:50 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Ignitor glowing?
The model appears to be a gas range whose oven uses a 'hot surface' (glow ignitor) ignition system. A first step in diagnosing possible causes will be to observe what the oven ignitor is doing when the oven should be heating.
You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link:
LINK > Understanding Gas Oven Ignition Systems
Not before you find out what and how much fixing yours is going to cost so you can make an informed decision between those options.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #3 (permalink)
Old 07-10-2009, 04:46 PM
Junior Member
Default
Thank you. We have determined that we had a bad igniter, and we now have the new part. I need help installing it though. Any tips or tricks?
  #4 (permalink)
Old 07-11-2009, 03:19 PM
Senior Expert
APP Volunteer
Wink Nuts
Nope, other than do NOT use plastic wire nuts if you have to cut and join the wires. Only porcelain or ceramic wires nuts should be used due to the heat in that area.
JMO
Dan O.
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
magic chef oven dorlid Washer Repair 0 01-01-2010 12:19 PM
magic chef oven bgmike8 Oven Repair (including Ranges and Cooktops) 1 06-01-2009 08:36 PM
Magic Chef Oven joannie Oven Repair (including Ranges and Cooktops) 0 05-10-2009 02:38 PM
Magic Chef Oven lessrob Oven Repair (including Ranges and Cooktops) 0 10-16-2008 09:11 PM
Magic Chef Oven going on by itself BobWall Oven Repair (including Ranges and Cooktops) 5 09-11-2008 07:18 PM
