I must set the temp on my Jenn-Air SVE47600B oven 40 to 50 degrees higher than the temp I really want. For example, if I want a 350 degree oven I must set the temp to 390 to 400 degrees. If I want a 400 degree oven I must set the temp to 440 to 450 degrees. Any suggestions? Thank you in advance.
