Discuss
rv range
 in
how do i remove the front burner on my stove it looks as though all the burners are one piece
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » rv range
  #1 (permalink)
Old 07-08-2009, 11:44 AM
usnat3 usnat3 is offline
Junior Member
usnat3 is on a distinguished road
Default rv range
Model Number: cly2232bdh   Brand: Magic Chef   Age: 5 - 10 years
how do i remove the front burner on my stove it looks as though all the burners are one piece with the tubes and valves. my front burner has started burning from the bottom of it and i dont want to blow any thing up it is the only one that will turn in circles which leads me to believe that it has burned out from the botttom
Related Models
Magic Chef CLY2232BDH Rv Range - Gas
Magic Chef CLY2235BDB Rv Range - Gas
Magic Chef CLY2241ADH Rv Range - Gas
Magic Chef CLY2241ADL Rv Range - Gas
Magic Chef CLY2241BDB Rv Range - Gas
Magic Chef CLY2241BDH Rv Range - Gas
Magic Chef CLY2241BDL Rv Range - Gas
Magic Chef CLY2241BDT Rv Range - Gas
Magic Chef CLY2242ADB Rv Range - Gas
Magic Chef CLY2242ADH Rv Range - Gas
Magic Chef CLY2242ADL Rv Range - Gas
Magic Chef CLY2242BDB Rv Range - Gas
Magic Chef CLY2242BDH Rv Range - Gas
Magic Chef CLY2242BDL Rv Range - Gas
Magic Chef CLY2242BDT Rv Range - Gas
Magic Chef CLY2245BDB Rv Range - Gas
Magic Chef CLY2245BDT Rv Range - Gas
Magic Chef CLY2248BDB Rv Range - Gas
Magic Chef CLY2249BDB Rv Range - Gas
Magic Chef CLY2253ADB Rv Range - Gas
Magic Chef CLY2253BDB Rv Range - Gas
Magic Chef CLY2260ADB Rv Range - Gas
Magic Chef CLY2260ADW Rv Range - Gas
Magic Chef CLY2260BDB Rv Range - Gas
Magic Chef CLY2260BDW Rv Range - Gas
Magic Chef CLY2262ADH Rv Range - Gas
Magic Chef CLY2262BDH Rv Range - Gas
Magic Chef CLZ8501ADL Rv Surface Unit - Gas
Magic Chef CLZ8501BDB Rv Surface Unit - Gas
Magic Chef CLZ8501BDH Rv Surface Unit - Gas
Magic Chef CLZ8501BDL Rv Surface Unit - Gas
Magic Chef CLZ8501BDT Rv Surface Unit - Gas
Magic Chef CLZ8502ADB Rv Surface Unit - Gas
Magic Chef CLZ8502ADH Rv Surface Unit - Gas
Magic Chef CLZ8502ADL Rv Surface Unit - Gas
Magic Chef CLZ8502BDB Rv Surface Unit - Gas
Magic Chef CLZ8502BDH Rv Surface Unit - Gas
Magic Chef CLZ8502BDL Rv Surface Unit - Gas
Magic Chef CLZ8502BDT Rv Surface Unit - Gas
Magic Chef CLZ8505BDB Rv Surface Unit - Gas
Magic Chef CLZ8505BDT Rv Surface Unit - Gas
Magic Chef CLZ8508BDB Rv Surface Unit - Gas
Magic Chef CLZ8509BDB Rv Surface Unit - Gas
Magic Chef CLZ8550ADB Rv Surface Unit - Gas
Magic Chef CLZ8550ADQ Rv Surface Unit - Gas
Magic Chef CLZ8550ADW Rv Surface Unit - Gas
Magic Chef CLZ8560ADB Rv Surface Unit - Gas
Magic Chef CLZ8560ADQ Rv Surface Unit - Gas
Magic Chef CLZ8560ADW Rv Surface Unit - Gas
Whirlpool CM02743BL1
Jenn-Air CM100 Surface Base Unit - Ddraft Ele
Jenn-Air CM100-E Surface Base Unit - Ddraft Ele
Crosley CM151 Mwave - Cntrtp / Stand Alone
Crosley CM153 Mwave - Cntrtp / Stand Alone
Magic Chef CM15K-7BS-NB Mwave - Mounted Over Range/wo
Magic Chef CM15KW-7BS-NB Mwave - Mounted Over Range/wo
Jenn-Air CM200 Surface Base Unit - Ddraft Ele
Jenn-Air CM200-E Surface Base Unit - Ddraft Ele
Thermador CM301B
Thermador CM301S
Thermador CM301W
Thermador CM302B
Thermador CM302S
Thermador CM302W
Crosley CM464G Mwave - Cntrtp / Stand Alone
Magic Chef CM46B-9P Mwave - Mounted Over Range/wo
Magic Chef CM46B-9P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46D-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46D-9P Mwave - Mounted Over Range/wo
Magic Chef CM46D-9P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46F-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46FN-8P-02 Mwave - Mounted Over Range/wo
Magic Chef CM46G-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46GN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM46H-14T Mwave - Mounted Over Range/wo
Magic Chef CM46HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM47F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM47FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM47H-14T Mwave - Mounted Over Range/wo
Magic Chef CM47HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM47J-14T Mwave - Mounted Over Range/wo
Magic Chef CM47JW-14T Mwave - Mounted Over Range/wo
Magic Chef CM48F-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM48FN-14T-02 Mwave - Mounted Over Range/wo
Magic Chef CM48H-14T Mwave - Mounted Over Range/wo
Magic Chef CM48HW-14T Mwave - Mounted Over Range/wo
Magic Chef CM48J-14T Mwave - Mounted Over Range/wo
Magic Chef CM48JW-14T Mwave - Mounted Over Range/wo
Amana CM601.000 Commercial Microwaves
Amana CM601.A Commercial Microwaves
Hardwick CM9641A590R Range - F/s Std Gas
Hardwick CM9641W590R Range - F/s Std Gas
Hardwick CM9641Y590R Range - F/s Std Gas
Amana CMA2000 Commercial Microwaves
Amana CMA2000B3 Commercial Microwaves
Amana CMA2000BK Commercial Microwaves
Amana CMA2230 Commercial Microwaves
Amana CMA2230B3 Commercial Microwaves
Maytag CME300 Mwave - Cntrtp / Stand Alone
Maytag CME301 Mwave - Cntrtp / Stand Alone
Maytag CME400 Mwave - Cntrtp / Stand Alone
Maytag CME500 Mwave - Cntrtp / Stand Alone
Maytag CME501 Mwave - Cntrtp / Stand Alone
Maytag CME601 Mwave - Cntrtp / Stand Alone
Maytag CME700 Mwave - Cntrtp / Stand Alone
Maytag CME701 Mwave - Cntrtp / Stand Alone
Maytag CME800 Mwave - Cntrtp / Stand Alone
Maytag CME8000AAB Mwave - Cntrtp / Stand Alone
Maytag CME8000AAE Mwave - Cntrtp / Stand Alone
Maytag CME8010AAB Mwave - Cntrtp / Stand Alone
Maytag CME8010AAE Mwave - Cntrtp / Stand Alone
Maytag CME900 Mwave - Cntrtp / Stand Alone
Maytag CME901 Mwave - Mounted Under Cabinet
Maytag CME9010AAB Mwave - Mounted Under Cabinet
Maytag CME9010AAE Mwave - Mounted Under Cabinet
Maytag CME9010BAB Mwave - Mounted Under Cabinet
Maytag CME9010BAE Mwave - Mounted Under Cabinet
Maytag CME9010CAB Mwave - Mounted Under Cabinet
  #2 (permalink)
Old 07-08-2009, 04:01 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Pressed together
The tube to the burner looks to just fit over the back end of the burner valve. There looks to be something in between called a "burner insert" but I am not familiar with that particular set up and don't know its purpose.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how to coverte LP range to natural gas range mani Oven Repair (including Ranges and Cooktops) 0 04-30-2009 05:51 PM
Replacing drop-in range with Slide-in range febrown Oven Repair (including Ranges and Cooktops) 3 03-23-2009 07:54 AM
ge gas range cstefan Oven Repair (including Ranges and Cooktops) 3 03-02-2009 06:13 AM
range archie palma Oven Repair (including Ranges and Cooktops) 1 01-25-2009 08:07 AM
range kantieau Oven Repair (including Ranges and Cooktops) 1 05-09-2008 03:48 PM
