Discuss
Jenn-Air Range, oven not heating
 in
I have a Jenn-Air Electric Range that the oven elements wont work. I replaced the oven sensor today and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Range, oven not heating
  #1 (permalink)
Old 08-07-2007, 07:20 PM
Mark Wise Mark Wise is offline
Junior Member
Mark Wise is on a distinguished road
Default Jenn-Air Range, oven not heating
Model Number: SVE47500   Brand: Jenn-Air   Age: More than 10 years
I have a Jenn-Air Electric Range that the oven elements wont work. I replaced the oven sensor today and it did have some heat damage on the wiring adaptor. However, there is no change. I have tried bake, broil and clean and none work. Sometimes it will flash a F5 code but not always. Most times, it will show that "preheat" is on but never heat up. I have inspected the upper and lower heating elements but found nothing obvious. Everything else works fine.
Related Models
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
Whirlpool SWU100W0
Whirlpool SWU100W2
Whirlpool SWU60W0
Whirlpool SWU60W2
Whirlpool SWU70W0
Whirlpool SWU70W2
Whirlpool SWU80W0
Whirlpool SWU80W2
Whirlpool SWU90W0
Whirlpool SWU90W2
  #2 (permalink)
Old 08-07-2007, 10:43 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Mark Wise
Pull the range out of the wall, remove the power, remove the back cover. You'll see the hi limit thermostat (#23 on the body break down diagram ). Check this part for continuity and if it is open then replace it. If this is not the issue then check all wires to heat elements and the oven sensor wire harness. If everything is fine then the electronic control board has to be replaced. The part number for the new control board is AP367441
Good luck.
  #3 (permalink)
Old 08-08-2007, 10:00 AM
Junior Member
Gene, thanks for the speedy response. I have checked the hi limit thermostat and it shows good, however I notice the small fan motor is "frroze up". Could this cause my problem?? Not sure how long it has not worked.
Thanks Again
Mark
  #4 (permalink)
Old 08-08-2007, 06:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mark Wise
Check the L2 connection on the control board, check wires first and then check the power with the L2 wires disconnected from the control board. It should be a 120V between the wire and the ground. Check the power between the wire goes to L2 terminal and the wire on the hi limit thermostat. It should be a 240V there. If there is nothing wrong then replace the control board. The part number for the new control board is AP367441 . If you do not know the safety rules how to work with electrical appliances it is better to call a certified tech to check all this stuff for you.
Good luck.
  #5 (permalink)
Old 02-09-2008, 02:48 PM
dan72 dan72 is offline
Junior Member
dan72 is on a distinguished road
Default
Im having an f5 code on jenn air model sve47600b was wondering if this could come from the relay board #28 in body break down diagram. Pulled back off unit this board was barely hanging on and has a burnt look to it. Oven not working but fan and top are. Thanks Daniel
  #6 (permalink)
Old 02-09-2008, 04:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The cause of the "F5" error code could be an intermittent contact on the power relay board or an intermittent oven temperature sensor (or it's wire harness).
A burned spot on the power relay board makes this part a very first failure suspect.
The part reference #28 is not the oven power relay board. It is the downdraft power relay board. The oven power relay board has the reference # 29 on the body break down diagram.
Make sure this is the part with a burned spot on it.
The downdraft power relay board
- The part number for the oven power relay board is AP204871
Here are the break down diagrams for the Jenn Air range Model SVE47600B
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not heating properly harry-homeowner Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:44 PM
oven not heating ljticeman Oven Repair (including Ranges and Cooktops) 1 08-01-2007 04:52 PM
jenn-air cooktop - diagnose correct part Michael Estep Oven Repair (including Ranges and Cooktops) 1 08-01-2007 02:18 PM
Jenn-Air Radiant Range with Convection Oven Dee Oven Repair (including Ranges and Cooktops) 0 07-24-2007 05:11 PM
electric range/oven clock not working 50fbn Oven Repair (including Ranges and Cooktops) 1 07-21-2007 12:47 AM
