| » Jenn Air Electric Cooktop duel burner |
Model Number: JEC9530ADB Brand: Jenn-Air Age: 1 - 5 years
The dual burner on my Jenn Air cooktop doesn't seen to work when the larger section is tunred on. At times it seems to be completely red however most of the time it isn't It doesn't seem to cook on the large side and if so only intermitently. Do I need a new eleement or other parts? I am ordering and wanted to know what you think is needed? Thanks.
Quote:
If power IS getting to the element but it was not heating, the element or limiter would likely be the problem and need to be replaced. (The limiter is only sold along with the element - see the link below) LINK > Dual Element and Limiter Asm. If power was NOT getting to the element when it stopped heating, the element switch (which on your model looks to be the 'custom control' circuit board - see the link below) or a loose connection in the wiring from it to the element could be responsible. LINK > Jenn-Air JEC9530ADB 'Custom Control' Dual Element Switch JFYI Dan O. www.Appliance411.com The Appliance Information Site =D~~~~~~ |
| Display Modes | |
| Old Jenn Air Cooktop - 6 burner (3 cartridge) | Norseman00 | Oven Repair (including Ranges and Cooktops) | 2 | 07-13-2011 09:36 AM |
| Electric Cooktop burner doesn't cycle on & off | natezn | Oven Repair (including Ranges and Cooktops) | 1 | 11-04-2009 06:25 AM |
| Access to replace Jenn-Air Cooktop Burner | jarepele | Oven Repair (including Ranges and Cooktops) | 1 | 05-29-2009 03:34 PM |
| whirlpool electric cooktop range inner burner not hot | posterboy42 | Oven Repair (including Ranges and Cooktops) | 3 | 10-03-2008 06:30 PM |
| Jenn Air Electric Cooktop | Mike Gallagher | Oven Repair (including Ranges and Cooktops) | 0 | 11-30-2007 06:48 PM |
