Model # JED8430ADB. What size wire is needed to hook up. Rated at 7KW at 240V. Also this unit has a blower attached at the bottom of unit. Does it suck air out or blow air into the unit and can the unit be used with out the blower/removed? Thanks SgtMajE9
