I have a Whirlpool Single Oven Model# (RBS305PRS00)that the light will not go out and when you start the bake mode, the display reads DOOR. Any ideas would be appreciated.
Quote:the light will not go out The oven interior light? Quote:when you start the bake mode, the display reads DOOR If it is the oven interior light that will not turn off, it sounds like the control 'thinks' the door is open (hence the light staying on). Is the door closing properly? It looks like the switch that turns on and off the oven interior light is part of the door latch assembly. If the door IS closing properly, that latch may be defective or one of its switches may just be out of alignment somehow. Someone is likely actually going to need to inspect that latch assembly for possible problems. LINK > Whirlpool RBS305PRS00 Door Latch Asm. (no picture) LINK > RBS305PRS00 Exploded Parts View IllustrationsJFYI Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
