I have this wall oven that we used very rear that i could even count it on my fingers. Just one day we want to use it and the oven won't work. None of the button won't do anything. Can anyone help me to figure out what's wrong with it. I tried to shut off the circuit breaker couple times already and nothing happen.
Open the control panel and unplug the control panel ribbon cable from the control board. Clean the edge connector with a pencil eraser. Do not use an ink eraser because it's too abrasive. Using an electronics contact cleaner or isopropyl alcohol and a tooth brush, clean the connector on the board.
Make sure it's dry and give it a try.
Post the results.
