Discuss
Electrolux Range Error code 15
 in
Our Electrolux range is 1 1/2 years old. We are receiving an error code 15. What is wrong? Thanks Robert
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electrolux Range Error code 15
  #1 (permalink)
Old 01-03-2012, 06:07 AM
Junior Member
Robert Roney is on a distinguished road
Default Electrolux Range Error code 15
Model Number: EW30ES65GSD   Brand: Electrolux   Age: 1 - 5 years
What is wrong?
Robert
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 01-05-2012, 05:59 AM
Banned
Chris_Polk is on a distinguished road
Default F15 error code
Typically this error means there is a signal loss between the EOC, electronic oven control, and the Oven Relay Board.
1. Test the harness and connections from EOC connector P16 to
Oven Relay Board J2.
2. Replace the Oven Relay Board.
3. Replace the EOC.
  #3 (permalink)
Old 01-05-2012, 06:22 AM
Junior Member
Default
Thanks Chris.......The error code is E 15...not F 15....is there a difference?
I have replaced the Control Board #316576610 and the Relay Board
#316442115 but still have the same problem. Is there something else
I should do?
  #4 (permalink)
Old 01-05-2012, 08:29 AM
Banned
Default E15
The only other information I can find from this manufacturer's field tech guide is the following.
An E015 error code may indicate the ESEC-UIB is not receiving a synchronization signal from the ESEC-Relay Board. Check first if J2 pin-5 on the ESEC-Relay Board is wired to P4 pin-5 on the ESEC-UIB. If wiring is good and the problem is still there, replace the ESEC-UIB. If the problem persists, replace the ESEC-Relay Board.
If you still have issues, I would suggest the connection or wiring between the two might be faulty and at that point would call in a tech if you have exhausted all other options.
Hope this helps!
  #5 (permalink)
Old 01-07-2012, 04:12 AM
Junior Member
Default
Chris, thanks for your help. Just one more question. We replaced the
OVEN relay board and the electronic OVEN control board. Both of these
boards pertain to the OVEN, right? Our oven works fine, it's the
cooktop that does not work. Any suggestions?
  #6 (permalink)
Old 05-24-2012, 05:27 PM
Junior Member
shenww is on a distinguished road
Default I have the same problem
Hi, Robert. I have the same problem. I have replaced the ESEC Relay board and ESEC 30 UIB, but it still showed E15. Can you tell me how to solve it if you have solved it. Thank you very much!
my email: weiwen.shen@gmail.com
  #7 (permalink)
Old 05-25-2012, 12:37 PM
Junior Member
Default
Shenww.....No, we have not solved the problem. Unfortunately, we bought
the stove in Houston and had it shipped to Costa Rica. Guess what? No
service available in the country. The service people here for other brands
will not touch it.
I have been in touch with customer service at Electrolux, but they only tell
you what is put in front of them....no real service training. I can not get
passed the customer service people to talk to a engineer or quality control
person.
If you live in the States try and get to an engineer at Electrolux and post
their answer....surely we are not the only two people with this problem.
They have to have documentation on what they did to solve this problem
other than what is in the manual.
If I don't find out something in the next two months, I am throwing this stove away and buying something local.
Please post if you find out something.
Robert Roney
  #8 (permalink)
Old 05-25-2012, 04:23 PM
Junior Member
Default The technician asked me to replace the touch panel
The technician has replaced the ESEC 30 UIB, ESEC Relay board, and checked harness and connections between these two boards, but it keeps showing Error 15.
I have read the service data sheet, J4 of the ESEC Relay board connects to the hot surface limiter of the cooktop, it' Ok. And P1-P14 of the ESEC Relay board output signals to control the elements of the cooktop, I don't think it effect the Relay board even if these are malfunctions. So the cooktop can't make the ESEC30 UIB showing Error 15.
Now the technician said I have to replace the touch panel, and it's approximate $930, and he can't guarantee it will be OK. Can you tell me how to make sure the touch panel is OK before I buy a new one?
  #9 (permalink)
Old 05-26-2012, 12:02 AM
Junior Member
Default
will not touch it.
person.
Robert Roney
Hi, Robert. Thank you for your reply. I'm in Canada. This range is one year warranty. My range is bought by the builder of my new house at June 2010. So Electrolux doesn't provide any repair service to me. The technician have been here three times to repair it, and I have spent proximate C$500, but the problem is still there. Now the technician said I should buy a $930 new touch panel, but he didn't guarantee it will be OK. So I don't want to pay more to repair it.
I have studied the service data sheet, I think there is problem in the touch panel. I guess it's a common problem for these types of Electrolux range,
but Electrolux doesn't want to be responsible for this after the warranty date.
  #10 (permalink)
Old 05-26-2012, 02:33 PM
Junior Member
Default
Thanks Shenww.....What you have gone thru tells me "they" don't know
what's wrong. That also tells me that I will "junk" the stove and buy local.
I'm glad you got on the forum....your info helped me make my final
decision. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrolux Slide in Range error code korniemd Oven Repair (including Ranges and Cooktops) 0 09-12-2011 06:07 AM
error code PF when i try to use my range MikkiJ24 Oven Repair (including Ranges and Cooktops) 0 10-10-2010 03:18 PM
Range Error Code JameyT Oven Repair (including Ranges and Cooktops) 0 08-28-2009 08:40 AM
GE Gas Range Error Code F1 RiverFisher Oven Repair (including Ranges and Cooktops) 1 01-09-2009 07:42 AM
WP Range Error Code E2/F3 go2geye Oven Repair (including Ranges and Cooktops) 1 04-24-2008 10:05 PM
