Hi, I have a jenn air model SVE47600B. The 4 buttons on the membrane that control the oven no longer do anything. When pressed, there is no beep, and no action from the oven itself. The other membrane butons work normally. Is there a way to ohm out the membrane to verify that it is ok, or do I have to assume that because some of them work, it is the circuit board behind the membrane that is the issue?
I've had my Jenn-air (Jgs8750adb) for 3 years and have needed to replace the control panel 3 times. I was told that it is caused by heat .... note: control panel is just above the oven door! Now they are telling me that the part is not available and for $278, they will install a replacement stove. I've spent $675 already on repair costs (labor not included in warranty) so now I'll be $950 over what I shelled out when I bought this piece of junk in 2006! My choice is to shell out $278 more or go out and buy a stove for $500 or more. This range should have been recalled.
