Discuss
Jenn-Air cartridge retro-fit 3 prong/4 prong
 in
Older Jenn-air cooktops swappable cartridges used 4 flat blade power prongs plus round pin - each burner or grill element
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air cartridge retro-fit 3 prong/4 prong
  #1 (permalink)
Old 01-02-2008, 10:32 AM
vfxmark vfxmark is offline
Junior Member
vfxmark is on a distinguished road
Default Jenn-Air cartridge retro-fit 3 prong/4 prong
Model Number: various   Brand: Jenn-Air   Age: More than 10 years
Older Jenn-air cooktops swappable cartridges used 4 flat blade power prongs plus round pin - each burner or grill element had its own feed from controller and return.
Newer cartridge set-ups use three prong (plus round pin) ... presumably the two elements share a common neutral.
Older four prong cartridges are no longer avail.
I want to purch. a three prong two-burner cartridge to use when not grilling/griddling but needing four burners total.
Which is easier and where can I purch conversion parts:
1. Add fourth prong to cartridge plug (which would just short between rightmost and neighboring prong)
2 re-wire existing outlet (or re-wire at controllers?)
Does anyone have any info on a mfr. "retro kit" which presumably would have been made avail when they changed wiring config?
Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rewiring 4 prong to a three prong nicolem Dryer Repair 1 12-13-2007 10:01 PM
Help with old Jenn Air SCE30600W David0250 Oven Repair (including Ranges and Cooktops) 0 12-02-2007 10:42 AM
Jenn Air gas oven won't heat kkenaga Oven Repair (including Ranges and Cooktops) 1 11-20-2007 01:45 PM
jenn air stove jsgt Oven Repair (including Ranges and Cooktops) 0 10-28-2007 05:12 PM
Jenn-Air Wiring ezra710 Oven Repair (including Ranges and Cooktops) 0 09-20-2007 09:39 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
