The oven control works sporadically. You can turn the oven on and set the temp but it will eventually turn itself off and you can hear a soft buzz sound. I have noticed that when it does turn on I can tap around on the Electronic oven control ( p/n AP3672811 ) and it will sometimes buzz and shut off. Looking on line I found references to a error code but have never seen one come up. It suggested that the problem could either be the EOC or the oven temp probe. Any help would be appreciated since we live in a very rural area and it is hard to get a technician out here.
Maybe a bad solder connection on the control board.
I don't see any loose solder connections, with this being a circuit board design could it be something in the connections inside? Is there anyway to check them or would I just need to buy a new Electronic oven control board?
