Groups ready for retrieval: Registered
The broil function and the range work fine but the bake function does not. I have turned the bake function on and checked the voltage on the safety valve and it is not getting the 3.2 volts like the broil function does when it is on. Is it the ignitor or the safety valve or something else?
