We have a Chambers 4 burner, built-in range. Most of the burners work either high or low, no in-between. Can they be adjusted, or should they be replaced? If replaced, can parts be found? Thank you
Most gas valves can be adjusted. Light each one , one at a time. Pull its respective knob off. Insert a very small regular tipped screwdriver down the hollow of the knob shaft. Turn the adjustment screw either direction to increase or decrease the flame. Test it throughout the entire range with the knob replaced, to ensure the flame doesn't extinguish at the lowest setting.
