Discuss
oven life expectancy?
 in
I was given an expensive estimate to repair the microwave in the Thermador double wall oven but it is already
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven life expectancy?
  #1 (permalink)
Old 07-06-2009, 11:14 AM
Junior Member
ladyann is on a distinguished road
Default oven life expectancy?
Model Number: CMT231   Brand: Thermador   Age: More than 10 years
I was given an expensive estimate to repair the microwave in the Thermador double wall oven but it is already 19 years old, so I'm wondering: what is the life expectancy of such an appliance?
Related Models
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000ADB MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000ADW MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BAB MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BAW MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BDB MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BDQ MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BDW MWAVE- MOUNTED UNDER CABINET
Maytag CMV1100AAB MWAVE- MOUNTED UNDER CABINET
Maytag CMV1100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag CMV1100AAW MWAVE- MOUNTED UNDER CABINET
Crosley CMW159PC MWAVE- CNTRTP / STAND ALONE
Crosley CMW22A2 MWAVE- CNTRTP / STAND ALONE
Crosley CMW22A6 MWAVE- CNTRTP / STAND ALONE
Crosley CMW419PD MWAVE- CNTRTP / STAND ALONE
Crosley CMW464G MWAVE- CNTRTP / STAND ALONE
Frigidaire CMWV150KBA MICROWAVE
Frigidaire CMWV150KWA MICROWAVE
Maytag CNDNS229J REF - SXS/I&W
Maytag CNDNS229JA REF - SXS/I&W
Maytag CNDNS229JH REF - SXS/I&W
Maytag CNDNS229K REF - SXS/I&W
Maytag CNDNS229KA REF - SXS/I&W
Maytag CNE200 RANGE- F/S STD ELE
Maytag CNE2000ACL RANGE- F/S STD ELE
Maytag CNE2000ACW RANGE- F/S STD ELE
Admiral CNEA100ACL RANGE- F/S STD ELE
Admiral CNEA100ACW RANGE- F/S STD ELE
Maytag CNG200 RANGE- F/S STD GAS
Maytag CNG201 RANGE- F/S STD GAS
Maytag CNG2010AAL RANGE- F/S STD GAS
Maytag CNG2010AAW RANGE- F/S STD GAS
Maytag CNG2010BAL RANGE- F/S STD GAS
Maytag CNG2010BAW RANGE- F/S STD GAS
Maytag CNNS208 REF - SXS
Maytag CNNS208H REF - SXS
Norge CNNS208K REF - SXS
Norge CNNS208KA REF - SXS
Maytag CNNT153L REF - TOP MOUNT
Maytag CNNT153LA REF - TOP MOUNT
Maytag CNNT156K REF - TOP MOUNT
Maytag CNNT156KA REF - TOP MOUNT
Maytag CNNT156KH REF - TOP MOUNT
Norge CNNT174HL REF - TOP MOUNT
Maytag CNNT174K REF - TOP MOUNT
Maytag CNNT174KA REF - TOP MOUNT
Maytag CNNT174KL REF - TOP MOUNT
Maytag CNNT174KLA REF - TOP MOUNT
Norge CNNT178BV REF - TOP MOUNT
Maytag CNNT198GA REF - TOP MOUNT
Maytag CNNT198GH REF - TOP MOUNT
Maytag CNNT198GLA REF - TOP MOUNT
Maytag CNNT198GLH REF - TOP MOUNT
Maytag CNNT198GLN REF - TOP MOUNT
Maytag CNNT198GN REF - TOP MOUNT
Maytag CNNT198K REF - TOP MOUNT
Maytag CNNT198KA REF - TOP MOUNT
Maytag CNNT198KL REF - TOP MOUNT
Maytag CNNT198KLA REF - TOP MOUNT
Crosley CNNT218BV REF - TOP MOUNT
Crosley CNNT218BVA REF - TOP MOUNT
Maytag CNP200 RANGE- F/S STD GAS
Maytag CNP201 RANGE- F/S STD GAS
Maytag CNP2010AXL RANGE- F/S STD GAS
Maytag CNP2010AXW RANGE- F/S STD GAS
Maytag CNP2010BXL RANGE- F/S STD GAS
Maytag CNP2010BXW RANGE- F/S STD GAS
Admiral CNPA100AXL RANGE- F/S STD GAS
Admiral CNPA100AXW RANGE- F/S STD GAS
Crosley CNS20M4 REF - SXS
Crosley CNS20M4A REF - SXS
Crosley CNS20M4H REF - SXS
Crosley CNS20M6 REF - SXS
Crosley CNS20M6A REF - SXS
Crosley CNS20M6H REF - SXS
Crosley CNS20T6 REF - SXS
  #2 (permalink)
Old 07-06-2009, 09:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
As long as a replacement parts available everything is repairable and can be "reanimated". The main question is: "Is it worth it?".
This microwave has been designed as a "helper" for regular baking. If you are going to use it as a regular microwave then be aware it has very low output compare to a new microwaves.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-06-2009, 09:54 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Question Suitable replacement??
You've probably already surpassed the average life span but there's no reason if repaired properly couldn't operate years to come yet. If you were thinking about replacing it you should also take into consideration the difficulty you're likely going to have finding a replacement that will fit in place of the original without a lot of cabinetry work.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No life at all rhondajean@aol.com Microwave Repair 1 02-19-2009 05:36 PM
