Discuss
Can I paint cast iron grates instead of replace
 in
I have purchased a used Kitchenaid stainless cooktop (5 burner). It is in great shape except for the grates. They
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Can I paint cast iron grates instead of replace
  #1 (permalink)
Old 07-06-2009, 07:58 AM
Junior Member
zeeru is on a distinguished road
Question Can I paint cast iron grates instead of replace
Brand: Kitchen Aid   Age: 1 - 5 years
I have purchased a used Kitchenaid stainless cooktop (5 burner). It is in great shape except for the grates. They look very used. Some parts the finish looks burnt off, maybe a little rusty. They are not chipped or missing pieces - just look bad. If there was a way to paint them
they would look brand new and I could save a lot of $$$. I thought I saw
a while ago a product made by "Harveys" it was a paint primer and paint. Now I can't find that product.
Ads By Google
  #2 (permalink)
Old 07-06-2009, 02:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think you can do it due to a very high temperature. Usually such parts have a porcelain surface.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-06-2009, 02:48 PM
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Unhappy NO paint for grates
I agree, no will will not likely be able to "paint" them. You might be able to have them reporcelained if replacements are prohibitively expensive or no longer available but that process is not usually cheap either.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
  #4 (permalink)
Old 07-06-2009, 03:37 PM
Junior Member
Default
They are not porcelain - they are cast iron. Aren't there paints out there for - say - fireplace parts that are cast iron.?
  #5 (permalink)
Old 07-06-2009, 07:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Iron casting is a technology used to make a different kind of products including a grates. Most of them then covered with porcelain to protect from rusting and make them looking better.
__________________
  #6 (permalink)
Old 07-06-2009, 08:02 PM
Senior Expert
APP Volunteer
Default
They're either cast and porcelained or forged (bent metal). I believe the forged grates are powder coated.
There is BBQ paint but those surfaces are not usually in direct heat like burner grates are. You could try it to see if it works to your satisfaction though.
JMO
Dan O.
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Can I replate or recoat gas cooktop burner grates? MUTTERT@NATIONWIDE.COM Oven Repair (including Ranges and Cooktops) 2 05-23-2010 01:59 PM
Whirlpool Range Ceramic Top & Cast Iron gooseamy101 Oven Repair (including Ranges and Cooktops) 0 02-11-2010 07:04 AM
