My wife was baking cookies the other day and completly fried the first batch. She has heat set at 350 and only 8 minutes, nothing out of the ordinary. She put in a second batch and the cookies never fully cooked. Now the oven will not fire at all. I replaced the ignitor on the oven burner and still nothing. It won't even click when turning the oven on. The broiler ignitor will click when you turn that on, but it doesn't light either. You cannot smell gas when opening the door. The stove top works just fine.
I do not know if I should replace the gas valve or if there is something else wrong. I am thinking it maybe some type of electric problem since the first batch completely fried and now the stove will not work until that is fixed. Could it be the temp sensor? Please help!
