Discuss
Oven lights-scaring the dog!
 in
Interior oven lights click on and off sporadically, usually when oven is not in use. Sometimes the light stays on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven lights-scaring the dog!
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-01-2008, 01:09 PM
Jmac Jmac is offline
Junior Member
Jmac is on a distinguished road
Default Oven lights-scaring the dog!
Model Number: ECS130   Brand: Dacor   Age: 1 - 5 years
Interior oven lights click on and off sporadically, usually when oven is not in use. Sometimes the light stays on for hours. Sometimes using the oven or messing with the touch pad will make the light go out. It is very annoying, but was told (via phone) that it is a very expensive fix. Any thoughts on what repair would be necessary?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-02-2008, 11:07 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is open the control panel, remove the touch pad ribbon from the control board slot and clean it, using an eraser.
Plug it back and check if the oven light works properly.
If not - the control panel has to be replaced.
If you need the right part number for the control panel, I need you to verify the model number and repost it together with the color of the control panel.
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Nothing Happens, All Lights flash Survivor Washer Repair 5 06-23-2008 07:10 PM
Dacor oven lights Elizabeth Siefker Oven Repair (including Ranges and Cooktops) 1 12-23-2007 08:45 AM
no lights Andyindra Refrigerator & Freezer Repair 1 12-17-2007 06:41 PM
Oven starts and lights but then goes out beinstein Oven Repair (including Ranges and Cooktops) 0 11-12-2007 12:53 PM
Oven lights and heats to Temp but goes out immediately!! jomo Oven Repair (including Ranges and Cooktops) 0 08-31-2007 09:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
