Discuss
Wierd Problem with Lighting range
 in
When I turn on any one of the burner controls to "light", the rear, right hand burner clicks
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wierd Problem with Lighting range
  #1 (permalink)
Old 07-03-2009, 06:04 PM
Mainechowder Mainechowder is offline
Junior Member
Mainechowder is on a distinguished road
Default Wierd Problem with Lighting range
Model Number: 465   Brand: Whirlpool   Age: 5 - 10 years
When I turn on any one of the burner controls to "light", the rear, right hand burner clicks and the ignitor sparks. When I turn on the controller for that burner, it sparks and lights. I can light them all manually. But none of the ignitors click or spark.
Thank you in advance to anyone that can help me out with this issue.
Don
Related Models
Amana 465.000 Mwave - Family Size (60 Hz)
Frigidaire 47-2151-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-00-02 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2151-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2151-23-02 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-02 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2251-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-00-05 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2251-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-02 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2251-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2251-23-05 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2351-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2351-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2451-00-01 Tap(v5) / 27 " Electric Dryer
Frigidaire 47-2451-00-03 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2451-23-01 Tap(v6) / 27 " Electric Dryer
Frigidaire 47-2451-23-03 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2451-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-00-01 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2551-00-03 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2551-23-01 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2551-23-03 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2551-23-04 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2707-00-01 Tap(v2)
Frigidaire 47-2707-23-01 Tap(v1)
Frigidaire 47-2751-00-01 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2751-23-01 Tap(v2) / 27 " Electric Dryer
Frigidaire 47-2828-00-01 Tap(v1) / Electric Dryer
Frigidaire 47-2828-00-03 Tap(v3) / Electric Dryer
Frigidaire 47-2828-00-04 Tap(v3) / 27 " Electric Dryer
Frigidaire 47-2828-23-01 Tap(v2) / Electric Dryer
Frigidaire 47-2828-23-02 Tap(v2) / Electric Dryer
Frigidaire 47-2828-23-03 Tap(v4) / Electric Dryer
Frigidaire 47-2828-23-04 Tap(v4) / 27 " Electric Dryer
Frigidaire 47-2848-00-01 Tap(v3) / Electric Dryer
Frigidaire 47-2848-00-02 Tap(v1) / Electric Dryer
Frigidaire 47-2848-00-03 Tap(v1) / Electric Dryer
Frigidaire 47-2848-00-04 Tap(v1) / 27 " Electric Dryer
Frigidaire 47-2848-23-01 Tap(v4) / Electric Dryer
Frigidaire 47-2848-23-03 Tap(v2) / Electric Dryer
Frigidaire 47-2848-23-04 Tap(v2) / 27 " Electric Dryer
Hoover 473.85920400 Extr - W/fix & Rot Brush,tempest
Hoover 473.85930400 Extr - W/fix & Rot Brush,tempest
Jenn-Air 4755 Range - F/s Std Ddraft Ele
Jenn-Air 4755N Range - F/s Std Ddraft Ele
Jenn-Air 4755S
Jenn-Air 4760 Range - F/s Std Ddraft Ele
Jenn-Air 4760N
Jenn-Air 4760S
Jenn-Air 4770 Range - F/s Std Ddraft Ele
Jenn-Air 4770N Range - F/s Std Ddraft Ele
Jenn-Air 4770S
Jenn-Air 4775 Range - F/s Std Ddraft Ele
Jenn-Air 4775N Range - F/s Std Ddraft Ele
Jenn-Air 4775S
Jenn-Air 4790 Range - F/s Std Ddraft Ele
Jenn-Air 4790N
Jenn-Air 4790S
Jenn-Air 4800 Range - F/s Std Ddraft Ele
Jenn-Air 4800N Range - F/s Std Ddraft Ele
Jenn-Air 4800S Range - F/s Std Ddraft Ele
Jenn-Air 4855 Range - F/s Std Ddraft Ele
Jenn-Air 4860 Range - F/s Std Ddraft Ele
Jenn-Air 4870 Range - F/s Std Ddraft Ele
Jenn-Air 4875 Range - F/s Std Ddraft Ele
Jenn-Air 4875S
Jenn-Air 4890 Range - F/s Std Ddraft Ele
Frigidaire 49-2151-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2151-23-02 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-02 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-02 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-23-04 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2351-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2351-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2451-00-01 Tap(v5) / 27 " Gas Dryer
Frigidaire 49-2451-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2451-23-01 Tap(v6) / 27 " Gas Dryer
Frigidaire 49-2451-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2551-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2551-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2551-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2551-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2707-00-01 Tap(v2)
Frigidaire 49-2707-23-01 Tap(v1)
Frigidaire 49-2751-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2827-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2827-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2828-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-03 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-04 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2828-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-02 Tap(v2) / Gas Dryer
Frigidaire 49-2828-23-03 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-04 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2847-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2847-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2848-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-02 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-03 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2848-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2848-23-03 Tap(v2) / Gas Dryer
Frigidaire 49-2848-23-04 Tap(v2) / 27 " Gas Dryer
Jenn-Air 4900 Range - F/s Std Ddraft Ele
Hoover 49811001 Frigidaire/refrigerator
Whirlpool 4ACE07LD0
Whirlpool 4ACE23LD0
  #2 (permalink)
Old 07-03-2009, 08:21 PM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Red face Model number incorrect
Quote:
Model Number: 465
I'm afraid that is not the model number of the appliance. You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
Quote:
When I turn on the controller [the rear, right hand burner], it sparks and lights. But none of the ignitors click or spark.
I guess you mean none of the other burners click or spark.
If that is the case, there may be a problem in the ignition switches on the burner valves or the wiring from them to the spark module or from the spark module to the burners.
All burners should usually spark together. If any aren't, there may be a problem in the wiring from the spark module to the malfunctioning burner(s).
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Range Hood Lighting PragmaticCynic Microwave Repair 0 02-09-2009 03:21 PM
Range - Not lighting/clicking on any eye weinsjs Oven Repair (including Ranges and Cooktops) 0 01-19-2009 11:58 AM
wierd appliance screws trotwood100 Microwave Repair 1 12-30-2008 07:59 AM
thermador range extra low burner not lighting BILL20850 Oven Repair (including Ranges and Cooktops) 0 10-08-2007 03:44 PM
