I have a bad membrane switch for a stainless model KEBS208DBL6 Kitchen Aid double convection Oven. Everyplace I've called and looked for online says the part is discontinued. I've been able to remove the membrane from the plastic housing and confirm the touchpad defective. If I flex it just the right way, the unit starts working again. What other options do I have? This is a perfectly good oven except this control panel membrane.
Thanks -Jeff
Originally Posted by: jf2615 I have a bad membrane switch for a stainless model KEBS208DBL6 Kitchen Aid double convection Oven. Everyplace I've called and looked for online says the part is discontinued. I've been able to remove the membrane from the plastic housing and confirm the touchpad defective. If I flex it just the right way, the unit starts working again. What other options do I have? This is a perfectly good oven except this control panel membrane.
Thanks -Jeff There is a company called Core Centric which refurbs touch pads and control panels. They refurbed my maytag double oven control panel and brought it back to life for about $125 including shipping....1/3 the cost of new. corecentricsolutions.com
