Discuss
ceramic cooktop: one ring of multi ring burner doesn't work
 in
My nephew has a GE ceramic cooktop stove (I don't have the model #). There is a 3 ring burner
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ceramic cooktop: one ring of multi ring burner doesn't work
  #1 (permalink)
Old 12-27-2011, 01:58 PM
Junior Member
DinosaurMike is on a distinguished road
Default ceramic cooktop: one ring of multi ring burner doesn't work
Brand: GE   Age: 5 - 10 years
My nephew has a GE ceramic cooktop stove (I don't have the model #). There is a 3 ring burner where the inner section does not work. There is a 3 position switch above the infinite switch to select which rings operate. Can anyone provide steps to troubleshoot the problem. I have not lifted the top to see if there is an obvious problem with the burner.
Thanks.
The model # is JB968SOK1SS
12/28 update: disconnected the three wires attached directly to the burner and checked continuity to the lead to the offshoot connectors. One lead was open, the other two gave resistance values. Took off the burner and the end of the inner element was broken where it went into the common terminal. Ordered a replacement burner.
Received and installed the new burner this afternoon. All three sections of the burner worked afterward. Disappointed no one replied to help with the troubleshooting process.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Gallery Outer Ring Burn Out Ceramic Top hutnik Oven Repair (including Ranges and Cooktops) 1 04-08-2011 08:39 PM
Balance Ring hitting Ring Tub and water on floor mrwto Washer Repair 5 02-01-2010 07:42 AM
Replacing Ring Deadening sound ring part # 63134 JOANBAPP Washer Repair 2 10-31-2009 06:56 PM
Changing Out Cooktop Ring Razorback Oven Repair (including Ranges and Cooktops) 1 10-07-2008 10:51 AM
