When the oven is set at 375, it cycles between 355 and 430. How can this be range be reduced? What range is acceptable?
Originally Posted by: larrybaker When the oven is set at 375, it cycles between 355 and 430. How can this be range be reduced? What range is acceptable? How did you measure it? Gene.
I measured three heating cycles with a thermometer in the oven.
Where and how did you place the thermometer?
When did you open the oven door to read the temperature?
Post everything you think can help.
