Discuss
bad ignitors?
 in
i have a 5 burner cooktop. 1 burner clicks and then ignites. the other 4 burners do not click. they
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bad ignitors?
  #1 (permalink)
Old 07-03-2009, 07:22 AM
tony-ngr tony-ngr is offline
Junior Member
tony-ngr is on a distinguished road
Default bad ignitors?
Model Number: glt3615lb02   Brand: Whirlpool   Age: 5 - 10 years
i have a 5 burner cooktop. 1 burner clicks and then ignites. the other 4 burners do not click. they will lite, but only if the first one is lit. they do not click but gas does come through. do i need new ignitors and how do i replace them?
Related Models
Whirlpool GLT3615LB02 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LQ0
Whirlpool GLT3615LQ01 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LQ02 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LT0
Whirlpool GLT3615LT01 36" Gas Glass Surface Cooktop
Whirlpool GLT3615LT02 36" Gas Glass Surface Cooktop
Whirlpool GLT3634LB0
Whirlpool GLT3634LQ0
Whirlpool GLT3634LT0
Whirlpool GLT3657RB00 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RB01 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RB02 36" Sealed Gas Cooktop
Whirlpool GLT3657RQ00 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RQ01 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RQ02 36" Sealed Gas Cooktop
Whirlpool GLT3657RT00 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RT01 36" Gas Glass Surface Cooktop
Whirlpool GLT3657RT02 36" Sealed Gas Cooktop
Frigidaire GLTF1040AS0 Frtld Wshr - Frig Gallery
Frigidaire GLTF1240AS0 Frtld Washer - Frig Gallery
Frigidaire GLTF1570ES0 Frigidaire/washer
Frigidaire GLTF1570ES1 Frigidaire/washer
Frigidaire GLTF1570FS0 Frigidaire/washer
Frigidaire GLTF1670AS0 Frtld Wshr - Frigidaire Gal
Frigidaire GLTF1670AS1 Frigidaire/washer
Frigidaire GLTF2070CS0 Frigidaire/washer
Frigidaire GLTF2070DS0 Frigidaire/washer
Frigidaire GLTF2940EE0 Frigidaire/washer
Frigidaire GLTF2940ES0 Frigidaire/washer
Frigidaire GLTF2940ES1 Frigidaire/washer
Frigidaire GLTF2940ES2 Frigidaire/washer
Frigidaire GLTF2940ES3 Frigidaire/washer
Frigidaire GLTF2940FE0 Frigidaire/washer
Frigidaire GLTF2940FS0 Frigidaire/washer
Frigidaire GLTF530DS0 Frigidaire/washer
Frigidaire GLTF530DS1 Frigidaire/washer
Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery
Frigidaire GLTR1670AS1 Frigidaire/washer
Whirlpool GLWA6900W0
Whirlpool GLWA6900W1
Whirlpool GLWA6900W2
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Whirlpool GLXA6900W0
Whirlpool GLXA6900W1
Whirlpool GLXA6900W2
Whirlpool GLXA6900W3
Gaggenau GM104-710
Gaggenau GM104-714
International GM1110PRW Range - F/s Std Gas
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
International GM3110MPAW Range - F/s Std Gas
International GM3110MXAW Range - F/s Std Gas
International GM3110PRAM Range - F/s Std Gas
International GM3110PRWM Range - F/s Std Gas
International GM31113WAM Range - F/s Std Gas
International GM31113WAV Range - F/s Std Gas
International GM3111GXAW Range - F/s Std Gas
International GM3111SXAW Range - F/s Std Gas
International GM31211XAW Range - F/s Std Gas
International GM3167WUA Range - F/s Std Gas
International GM3167WUV Range - F/s Std Gas
International GM3210MXAW Range - F/s Cont Clean Gas
International GM3211GXAA Range - F/s Cont Clean Gas
International GM3211GXAW Range - F/s Cont Clean Gas
International GM3211SXAA Range - F/s Cont Clean Gas
International GM3211SXAW Range - F/s Cont Clean Gas
International GM3216WRWM Range - F/s Cont Clean Gas
International GM32211XAW Range - F/s Cont Clean Gas
International GM3267WUAM Range - F/s Cont Clean Gas
International GM3267WUWM Range - F/s Cont Clean Gas
International GM3267XUA Range - F/s Cont Clean Gas
International GM3267XUAM Range - F/s Cont Clean Gas
International GM3267XUW Range - F/s Cont Clean Gas
International GM3267XUWM Range - F/s Cont Clean Gas
Gaggenau GM335-760
Maytag GM3468XUW-X Range - S/c F/s Gas
Maytag GM3468XUWX Range - S/c F/s Gas
International GM3510PRW Range - F/s Std Ele
International GM3531WUV Range - S/c F/s Ele
International GM3531WUW Range - S/c F/s Ele
International GM3631XUA Range - F/s Std Ele
International GM3631XUW Range - F/s Std Ele
International GM3862XUW Range - S/c F/s Ele
  #2 (permalink)
Old 07-03-2009, 09:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Sounds like the problem is a bad ignition switches. You have to remove the cooktop from the counter to access the parts.
- The part number for the ignition switch harness is AP3592411
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GLT3615LB02 | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 07-04-2009, 12:14 AM
Dan O. Dan O. is offline
Senior Expert
APP Volunteer
Dan O. is on a distinguished road
Lightbulb Ignition switch(es)/Wiring
There may be a problem with the ignition switches on the burner valves or in their wiring. All of the switches come together in an assembly along with their wiring (see the following link).
LINK > Whirlpool GLT3615LB02 Ignition Switch/Wiring Asm.
There are spark electrodes at the burners but if they were defective they should not work when that one burner was turned on either. There is a spark module but only one so it shouldn't be the problem if even one burner worked reliably. That leaves the ignition switches for those 4 burners not powering the spark module either due to their failure of failure of their wiring.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help with gas stovetop ignitors stratmaster Oven Repair (including Ranges and Cooktops) 0 05-13-2009 06:35 PM
ignitors go when I plug in brianlund Oven Repair (including Ranges and Cooktops) 0 03-31-2009 03:33 PM
Burner ignitors always on! Myers521@mchsi.com Oven Repair (including Ranges and Cooktops) 1 08-20-2008 09:23 PM
Ignitors won't click hydrospirit Oven Repair (including Ranges and Cooktops) 5 02-04-2008 12:45 AM
Ignitors Won't Shutdown rlawrence Dishwasher Repair 6 01-25-2008 04:29 PM
