After using the self clean feature on the lower of double oven, setting oven to bake at 350, it only goes to 107 and no further. This happened once before and the repair man wrote on the order, reset hi-limit, tested and charged me $88.00. Anyone know how to reset hi-limit. This unit has a control pad, no knobs.
I conferred with a service man who told me how to reset the Hi-limit on the lower oven which would not heat after using the self cleaning feature. Open the lower door and remove the vent where the latch is. I took out four screws and then had to take off the top oven door to get the other three screws. There is a small round device with a red button. Push the button in all the way and that's it. The oven works now.
